How can I generate a previous version of the SDK?
m4l490n
Contributor V
I'm working on a team that is using MCUXpresso 10.2.1 and the SDK V2.4.1 they generated a while ago and have not updated. I'm trying to replicate the setup but the sdk generation website does not have an option for the SDK version. I'm using MCUXpresso 10.2.1 but the site only generates SDK version 2.5.0 and that is not compatible, therefore I'm having issues with my project.
Is it possible to generate a different SDK version than the most recent?
Thanks!
danielchen
Hi Manuel:
MCUXpresso SDK build only generate SDK for the latest version.
If you downloaded some version before, you can access your MCUXpresso SDK Dashboard, you can download this version again.
Which MCU you want to download?
