FreeRTOS I2C Example on FRDM_K66 Master Error on Write
2,123 次查看
jeremyanderson
I'm using MCUExpresso IDE with SDK2.x.  I've imported the SDK example of freertos I2c.  Everything works fine with compiling and debugging, but it always fails with a kStatus_I2C_Addr_Nak.  Is there something I need to do with teh board to make this example work?
1,816 次查看
jeremyanderson
OK, RTFM.  Problem solved.  Read the doc/readme.txt file and the proper connections are shown.
1,817 次查看
jeremyanderson
