Flex NVM?
Flex NVM?
2,666 次查看
akshita_manwati
What is the exact meaning of Flex NVM?
2,523 次查看
Luis_Garabo
The FlexNVM - It is a Nonvolatile flash memory that can execute program code, store data or back up emulated EEPROM data. It is used in a lot of our MCUs. For instance:
Kinetis: https://www.nxp.com/docs/en/application-note/AN4282.pdf
S32K: https://www.nxp.com/docs/en/application-note/AN12003.pdf
Kind Regards,
Garabo
