Files missing from the MIMX9331 SDK
1,873件の閲覧回数
TK6223
I started writing our firmware using a development board that had a MIMX9352 SoC. Our own hardware has a MIMX9331 SoC, so I downloaded the SDK (25.09) for that chip and updated the project files to use the correct SDK. This resulted in the build failing because the following files were missing:
components/uart/component_lpuart_adapter.MIMX9331.cmake
devices/MIMX9331/all_lib_device.cmake
devices/MIMX9331/cmsis_drivers/driver_cmsis_lpi2c.MIMX9331.cmake
devices/MIMX9331/device_CMSIS.MIMX9331.cmake
devices/MIMX9331/device_startup.MIMX9331.cmake
devices/MIMX9331/device_system.MIMX9331.cmake
devices/MIMX9331/drivers/driver_cache_xcache.MIMX9331.cmake
devices/MIMX9331/drivers/driver_clock.MIMX9331.cmake
devices/MIMX9331/drivers/driver_common.MIMX9331.cmake
devices/MIMX9331/drivers/driver_iomuxc.MIMX9331.cmake
devices/MIMX9331/drivers/driver_lpi2c_edma.MIMX9331.cmake
devices/MIMX9331/drivers/driver_lpuart.MIMX9331.cmake
devices/MIMX9331/drivers/driver_memory.MIMX9331.cmake
devices/MIMX9331/drivers/driver_rgpio.MIMX9331.cmake
devices/MIMX9331/drivers/edma4/driver_edma4.MIMX9331.cmake
devices/MIMX9331/utilities/debug_console_lite/utility_assert_lite.MIMX9331.cmake
devices/MIMX9331/utilities/utilities_misc_utilities.MIMX9331.cmake
devices/MIMX9331/utilities/utility_debug_console_lite.MIMX9331.cmake
devices/MIMX9331/utilities/utility_str.MIMX9331.cmake
The SDK for the MIMX9331 contains also the MIMX9352 files under devices, and the corresponding files for the 9352 exist there. As a workaround I've manually copied the missing files from the 9352 directory and renamed them (+ fixed the contents to refer to the 9331 when necessary).
Will the missing MIMX9331 files be added in an upcoming release?
2 返答(返信)
1,869件の閲覧回数
Bio_TICFSL
Please take this appnote for differences between MX91 and MX93.
https://www.nxp.com/docs/en/application-note/AN14012.pdf
1,713件の閲覧回数
TK6223
Thanks for the reply! These are both i.MX93 chips so I don't see how the MX91 would be relevant here, but please correct me if I'm wrong.
And shouldn't there at least be the all_lib_device.cmake file with the corresponding configuration for the MIMX9331? I didn't check the peripherals related to each of the missing files, but for example the driver_clock, driver_common, driver_iomuxc and driver_rgpio files definitely sound like something that should be there.
%3CLINGO-SUB%20id%3D%22lingo-sub-2174218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMIMX9331%20SDK%E3%81%8B%E3%82%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174218%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A7%81%E3%81%AF%E3%80%81MIMX9352%20SoC%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AE%E4%BD%9C%E6%88%90%E3%82%92%E5%A7%8B%E3%82%81%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%AF%20MIMX9331%20SoC%20%E3%81%8C%E6%90%AD%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%81%9D%E3%81%AE%E3%83%81%E3%83%83%E3%83%97%E7%94%A8%E3%81%AE%20SDK%20(25.09)%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E6%AD%A3%E3%81%97%E3%81%84%20SDK%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9D%E3%81%AE%E7%B5%90%E6%9E%9C%E3%80%81%E6%AC%A1%E3%81%AE%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%9F%E3%82%81%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%2Fuart%2Fcomponent_lpuart_adapter.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2Fall_lib_device.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2Fcmsis_drivers%2Fdriver_cmsis_lpi2c.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9_CMSIS.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2Fdevice_startup.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%82%B7%E3%82%B9%E3%83%86%E3%83%A0.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fdriver_cache_xcache.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fdriver_clock.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fdriver_common.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fdriver_iomuxc.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fdriver_lpi2c_edma.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fdriver_lpuart.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fdriver_memory.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fdriver_rgpio.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%89%E3%83%A9%E3%82%A4%E3%83%90%2Fedma4%2Fdriver_edma4.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%2Fdebug_console_lite%2Futility_assert_lite.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%2Futilities_misc_utilities.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%2Futility_debug_console_lite.MIMX9331.cmake%3CBR%20%2F%3E%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%2FMIMX9331%2F%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%2Futility_str.MIMX9331.cmake%3C%2FP%3E%3CP%3EMIMX9331%20%E3%81%AE%20SDK%20%E3%81%AB%E3%81%AF%E3%80%81%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E4%B8%8B%E3%81%AB%20MIMX9352%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E5%90%AB%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%819352%20%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%82%E3%81%9D%E3%81%93%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E5%9B%9E%E9%81%BF%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E3%80%81%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%209352%20%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%8B%E3%82%89%E6%89%8B%E5%8B%95%E3%81%A7%E3%82%B3%E3%83%94%E3%83%BC%E3%81%97%E3%80%81%E5%90%8D%E5%89%8D%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20(%2B%20%E5%BF%85%E8%A6%81%E3%81%AB%E5%BF%9C%E3%81%98%E3%81%A6%209331%20%E3%82%92%E5%8F%82%E7%85%A7%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E5%86%85%E5%AE%B9%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F)%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%20MIMX9331%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E4%BB%8A%E5%BE%8C%E3%81%AE%E3%83%AA%E3%83%AA%E3%83%BC%E3%82%B9%E3%81%A7%E8%BF%BD%E5%8A%A0%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Files%20missing%20from%20the%20MIMX9331%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185811%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%94%E4%BF%A1%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AF%E4%B8%A1%E6%96%B9%E3%81%A8%E3%82%82%20i.MX93%20%E3%83%81%E3%83%83%E3%83%97%E3%80%81SO%E3%80%81MX91%20%E3%81%8C%E3%81%93%E3%81%93%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E9%96%A2%E4%BF%82%E3%81%99%E3%82%8B%E3%81%AE%E3%81%8B%E3%82%8F%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%82%89%E8%A8%82%E6%AD%A3%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%A8%E3%82%82%20MIMX9331%20%E3%81%AB%E5%AF%BE%E5%BF%9C%E3%81%99%E3%82%8B%E6%A7%8B%E6%88%90%E3%82%92%E6%8C%81%E3%81%A4%20all_lib_device.cmake%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%8C%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%E4%B8%8D%E8%B6%B3%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%90%84%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%83%9A%E3%83%AA%E3%83%95%E3%82%A7%E3%83%A9%E3%83%AB%E3%81%AF%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8C%E3%80%81%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81driver_clock%E3%80%81driver_common%E3%80%81driver_iomuxc%E3%80%81driver_rgpio%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E7%A2%BA%E3%81%8B%E3%81%AB%E5%AD%98%E5%9C%A8%E3%81%99%E3%82%8B%E3%81%AF%E3%81%9A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2174324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Files%20missing%20from%20the%20MIMX9331%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2174324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%0A%3CP%3EMX91%20%E3%81%A8%20MX93%20%E3%81%AE%E9%81%95%E3%81%84%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E3%81%93%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14012.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14012.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
