Example project for i.Max RT1176 UART Hardware Flow control RTS/CTS
2,229 次查看
MN19000
Please provide or guide me to find an example project in MCUXpresso IDE that support LPUART RTS/CTS hardware flow control.
标记 (1)
2,167 次查看
diego_charles
Hi @MN19000
You can get the demo by downloading our SDK, go to  SDK Builder  and select Development board.
I recommend you using an IDE to confortably navigate througth the code.  See our IDE options here MCUXpresso Suite of Software and Tools. MCUXpresso IDE is very user friendly.
I hope this could help you.
Diego
5 回复数
2,100 次查看
Bramo
Have you checked out the MCUXpresso SDK examples?
2,200 次查看
diego_charles
Hi @MN19000
Many thanks for reaching us.
Currently we  have lpuart_hardware_flow_control demos for the RT10xx series. You can use as reference  lpuart_hardware_flow_control of the the RT1060 SDK. This demo simple enables the RTS/CTS pins and uses an config structure. The demo is intended to work on a self loopback mode.
I have not tested this yet, on our RT1176 EVK, but I think the LPUART API should support you to enable this functionality.
If you have issues or further questions do not hesitate to reach again.
Diego
2,175 次查看
MN19000
Hi Diago,
Could you please send me the link to  lpuart_hardware_flow_control demos or direct me how to find it?
2,168 次查看
diego_charles
Hi @MN19000
Diego
2,205 次查看
MN19000
Any update on this case:
