Error charging SDK files when starting MCUxpresso
已解决
跳至解决方案
2,467 次查看
asier
After trying to import a new SDK from "Welcome\Download and Install SDKs\Processors", it fails.
In "Installed SDKs" it appears my existing installed SDK files and a new line with null name and a location "https://mcuxpresso.nxp.com/eclipse/sdk...".
After that, problems appears when charging SDK files when it starts.
Any helping ? thanks,
Asier.
P.D. Attached screenshoot of error window.
1 解答
2,457 次查看
danielchen
Hi @asier :
Do you use MCUXpresso IDE 11.3.0?  If not, I would suggest you try the new version again.
https://www.nxp.com/design/software/development-software/mcuxpresso-software-and-tools-/mcuxpresso-i...
Please let me know the detail steps to reproduce your issue on my side.
在原帖中查看解决方案
2 回复数
2,458 次查看
danielchen
Hi @asier :
2,452 次查看
asier
Hi Daniel,
I was using 11.2.0 version.
I've installed 11.3.0 as you tell me. Then I drag&drop the new zip sdk file ant it goes right.
Thank you and regards,
Asier.
