DMA Tcd
DMA Tcd
AsafTv
i use MK64FN1m0xx12
i configure 4 TCD for DMA work as ping pong, How can i know the current running DMA TCD?
CarlosGarabito
CarlosGarabito
Hi, we have a document than can help you
https://www.nxp.com/docs/en/application-note/AN5083.pdf
AsafTv
what can be the reason that DMA stop to work if i configure interrupt priority to the DMA channel
CarlosGarabito
Hi again, Maybe need to check your interrupt code
Have a good day
AsafTv
I use NVIC_setPriority ( DMA1_IRQn ), what can be the problen?
if i not set the priority what is the reset priority?
