Changing associated SDK during project development
1,429 次查看
MISO_27
Hello community,
is it possible to change the SDK associated to/used in a project?
I started development with an evaluation board using the IMXRT1170-EVK SDK but want to switch to the evalboards processor SDK (IMXRT1176xxx). A folder diff showed they are both identical concerning the used drivers, yet I don't know how to change which SDK is being used in the project.
Any suggestions?
1,408 次查看
Omar_Anguiano
Hello
Hope you are well.
There might be some differences in the modules or other features. You can change the MCU settings for the part:
However, I suggest you start a new project for the target device and import your source files.
If you have more questions do not hesitate to ask me.
Omar
