CAN communicate one time but on second time not
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
I am trying to communicate with CAN to another module. One time I got it, but when i send another time it stays in loop in txComplete = false. I don´t know what is wrong in my software. In KDS I got it doing 3 or 4 or any time with this module. I don´t know why with mcuxpresso i can´t. I am using MK22FN1M0AVLL12. Anybody can help me? I think the problem could be a flag but i don´t know what.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Alexandre V.D.P,
I highly suggest you try the official SDK code for your MK22FN1M0AVLL12 at first.
You can download the SDK code from this link:
https://mcuxpresso.nxp.com/en/select
This code default chip is for TWR-KV21F120M board, but if you download the MK22FN1M0AVLL12 sdk code, the according header files , drivers and the system_chip files from this folder:
\SDK_2.3.1_MK22FN1M0Axxx12\devices\MK22FA12
The project you can refer to this folder code:
SDK_2.3.1_MK22FN1M0Axxx12\boards\twrk21f120m\driver_examples\flexcan\interrupt_transfer
But when you use the MCUXpresso IDE, please change the header file, the MCU part number, the system files, and the startup files, all these can be found from folder:
Please try it on your side.
Kerry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I am trying to send to another side but I wait for rxComplete and not goes to true. I am using the example, not works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Alexandre,
Do you use the PC CAN analyzer side software to test it? What about the send, whether it works or not?
About the receive, please also check the ID filter, do you send out the correct ID in the other CAN node.
If you still have question about it, please send me your detail test result with the CAN analyzer.
Please also check your CAN transceiver, make sure the CAN hardward side don't have problems.
Kerry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Can I send my example to you. The PLACA MITL sends to DETECTOR1. If DETECTOR 1 responds the PLACA MITL turn on the led and turn off the led. It sends on time and receive but in second time it stops in txComplete. The communication is ok, I did the configuration of speeds inside of
FLEXCAN_GetDefaultConfig(&flexcanConfig);
My problem I think is some flag that is not cleaning but i don´t know who create the code and I need help to make the communication.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Alexandre,
You can send me your test project.
But, from tomorrow, I will on our Chinese Spring Festival, I will back on February 11th.
So, I will reply you on 2019 February 11th. If you are in a hurry, you can create the new case, then my other colleague also will help you!
Thanks a lot for your understanding and sorry for the inconvenience I bring you!
Kerry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
But how can i send a archive to you. From here it is impossible
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You can attached it in the advanced editor.
Kerry
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No don´t have problems because I can communicate with a power supply that have CAN and the other board I tested with power supply and the CAN works. I can send my software to you. I think could be some configuration. My problem is communicate board to board. The power supply other guy make on ST microcontroller.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
I need a example of CAN transmission and receive that in one side I transmit and other waits to receive by a interrupt flag.
