Bug fsl_sdif.c
Bug fsl_sdif.c
jensen_j
Hi, hope i'm right here.
Found a bug in fsl_sdif.c from the SDK_2.6.0. (i use the LPC54605J256).
The cardRemoved Callback isn't assigned in the SDIF_TransferCreateHandle(...) Function ~Line1316.
Best Regards
Jürgen
jeremyzhou
Hi juergen.josef,
Thank you for your interest in NXP Semiconductor products and
the opportunity to serve you.
Thanks for your bug reporting, I'll transfer the report to the SDK team for checking.
TIC
