Hi embeddeddavid,
In some of our internal side, I find one of our expert modify the code like the following, define the ENET_TXBUFF_SIZE to 256, and can make it works.
So, make be you can use 256, you can try it.
#ifndef ENET_RXBD_NUM
#define ENET_RXBD_NUM (8) //(5)
#endif
#ifndef ENET_TXBD_NUM
#if defined(FSL_FEATURE_SOC_LPC_ENET_COUNT) && (FSL_FEATURE_SOC_LPC_ENET_COUNT > 0)
#define ENET_TXBD_NUM (5)
a
#else
#define ENET_TXBD_NUM (8) //(3)
#endif
#endif
#ifndef ENET_RXBUFF_SIZE
//a
#define ENET_RXBUFF_SIZE 256//(ENET_FRAME_MAX_FRAMELEN)
#endif
//a
#ifndef ENET_TXBUFF_SIZE
#define ENET_TXBUFF_SIZE 256//(ENET_FRAME_MAX_FRAMELEN)
#endif
In fact, I didn't find the detail TX Min limit content now, you can try 256, whether it works with the above code?
Kerry
