warning: could not convert 'main' from the host encoding (CP1252) to UTF-32
2,128 次查看
LEO531003
i use MCXN947 and i want to use ADC and write code but the warning always happened. then i created a new project to debug, it still happened.  I tried to clean, but still not work.
warning: could not convert 'main' from the host encoding (CP1252) to UTF-32.
This normally should not happen, please file a bug report.
2,111 次查看
EdwinHz
Hi @LEO531003,
Please try making a new workspace before creating/importing the project that you are using. Like it is mentioned on the following post, it's always a good idea to create a new workspace when changing IDE version:
MCUXpresso + Jlink - Cannot convert encoding - NXP Community
BR,
Edwin.
