"Error in final launch sequence" with NXP 1062
tomdunigan
With MCUXpresso and 1062 eval board, I had successfully loaded and run a project a couple of times.  I made a change which I suspect caused a memory exception, and now I cannot load/run a new project on that board (I've since tried an NXP 1050 board and upload/run worked).  Here is what the IDE pops up
I've tried deleting project and refetching it.  i've tried rebooting ubuntu-64 host.  I've tried uploading blinky ... all fail as above for that board.   How do I fix this?
lpcxpresso_supp
In the first place, please read the blog article we have available in this community on using the IDE with these boards  - in particular the troubleshooting section.
https://community.nxp.com/community/mcuxpresso/mcuxpresso-ide/blog/2019/01/23/overview-of-using-the-...
MCUXpresso IDE Support
