With MCUXpresso and 1062 eval board, I had successfully loaded and run a project a couple of times. I made a change which I suspect caused a memory exception, and now I cannot load/run a new project on that board (I've since tried an NXP 1050 board and upload/run worked). Here is what the IDE pops up
I've tried deleting project and refetching it. i've tried rebooting ubuntu-64 host. I've tried uploading blinky ... all fail as above for that board. How do I fix this?
In the first place, please read the blog article we have available in this community on using the IDE with these boards - in particular the troubleshooting section.
MCUXpresso IDE Support
