greenhill support in MCUXpresso
ConstYu
Customer ask is it possible to use green hill complier in MCUxpresso IDE?
Can the elf generated by green hill be use used to debug in  MCUxpresso IDE?
ErichStyger
Senior Contributor V
is it possible to use green hill comiler in MCUxpresso IDE?
Yes. GHS provides an Eclipse plugin as well, or you can use make files too.
Yes, any standard ELF/Dwarf files (including the ones created by GHS) can be debugged.
I hope this helps,
Erich
ErichStyger
I hope this helps,
Erich
ConstYu
Hi @ErichStyger ,
Thanks for your fast reply on this topic, one more question, do we have a guide to introduce how to install this Eclipse plugin for MCUXpresso, or is there any document which can be refer?
ErichStyger
The folks at Greenhills for sure would be the best contact, but you can try this:
https://www.eclipse.org/forums/index.php/t/210115/
