greenhill support in MCUXpresso
2,447 次查看
ConstYu
Customer ask is it possible to use green hill complier in MCUxpresso IDE?
Can the elf generated by green hill be use used to debug in  MCUxpresso IDE?
2,443 次查看
ErichStyger
Specialist I
is it possible to use green hill comiler in MCUxpresso IDE?
Yes. GHS provides an Eclipse plugin as well, or you can use make files too.
Yes, any standard ELF/Dwarf files (including the ones created by GHS) can be debugged.
I hope this helps,
Erich
2,444 次查看
ErichStyger
Specialist I
I hope this helps,
Erich
2,431 次查看
ConstYu
Hi @ErichStyger ,
Thanks for your fast reply on this topic, one more question, do we have a guide to introduce how to install this Eclipse plugin for MCUXpresso, or is there any document which can be refer?
2,429 次查看
ErichStyger
Specialist I
The folks at Greenhills for sure would be the best contact, but you can try this:
https://www.eclipse.org/forums/index.php/t/210115/
