I'm trying to create a project using MCUXpresso V11 to run on a FRDM-KV31 eval board. I started with File->New->New C/C++ Project (SDK Wizard), selected the eval board and added a few components. When I tried to open Config Tools -> Open Pins I get the message in the question above. I have SDKs installed for both the eval board and the processor. I believe the IDE can access the internet since Check Updates works OK.
How do I get past this?
Hello Lance,
MKV31F512xxx12 is supported by the Config Tools v7.0. Could you please attach the <user home>/.nxp/swtools.log and <workspace>/.metadata/.log file ? There might be some helpful information related to this problem. It might be network/proxy error.
As a workaround you can go to mcuxpresso.nxp.com and download Config Tools Offline data for this processor and then import them using "File | Import ... | MCUXpresso Config Tools | Import Processor Data" wizard.
Libor
