Warning text unreadable in dark color theme
scottm
Senior Contributor II
I'm not sure where minor bug reports for the IDE should be reported - this doesn't seem to be worth opening a ticket for.
In MCUX v11.6.1 when dark mode is enabled, the console view renders compiler warnings in white-on-white text. Also, the entire view starts out white until it gets focus for the first time.
This is just a nuisance since you can still read the text by selecting it, but it seems like it should be a quick fix.
Scott
ZhangJennie
Hi Scott
Could you please send us screenshots about this problem?
Jun Zhang
scottm
Also, here's a screenshot showing how the console looks right after MCUX is launched:
And then after it's been clicked on:
scottm
I intended to do that initially but it told me I didn't have privileges to upload images. Here's an example. You can see that the gcc warnings are all white-on-white. I've selected some text so you can see that the message is still there.
Scott
ZhangJennie
HI @scottm
I got update that this problem will be fixed in MCUXpresso IDE v11.7.0
Jun Zhang
scottm
Thanks!
ZhangJennie
Hi Scott,
Thanks for your reply. I reproduced it.
I will report to IDE team to fix it.
Thanks for bringing the problem to our attention.
Jun Zhang
