Using MCUXpresso 11.8.1 build 1197 had an firmware update to PE Micro Multilink FX
2,978 次查看
GregT
The popup box said upgrading to firmware 11.22.  Then a popup comes up saying it could not connect.  See pics below.  Windows does not recognize it as a USB device.  Any ideas?
2,936 次查看
ZhangJennie
Hi GregT
The latest P&E firmware update file is included in USB Multilink Resources Install
https://www.pemicro.com/downloads/download_file.cfm?download_id=346
If you need a specific update version that is not included in this package, you ccould ontact P&E support to reuqest.
Hope this will help you,
Jun Zhang
2,901 次查看
GregT
Thanks for the response. I had to run a few times and power cycle and finally the firmware upgrade completed and I was able to use it.
2,876 次查看
ZhangJennie
Thanks for your feedback. Good to know it works now.
Have a nice day,
Jun Zhang
