Unresolved inclusion
3,850 次查看
biafra
Senior Contributor I
Hi everyone,
I'm using MCUXpresso 24.9.
For some reasons in my project I needed to chnge the compiler command line. The chenges are working fine, the project is built without problem.
But there is a side effect: the indexer is not able to resolve lib include files:
To debug the problem I created a test program with the default options (New Project -> Create a new C/C++ project), then I changed the command line to compile the project (Project properties -> C/C++ Build -> Settings -> MCU C compiler) from the default value ("arm-none-eabi-gcc") to "../compile.cmd":
The file compile.cmd is located in the project directory and contains the single line:
arm-none-eabi-gcc %*
If I compile the program the process is terminated without errors, but all the c library files are highlighted as unresolved inclusions: so the problem belongs only to the indexer.
When there is the default setting no highlight is present and in the <WorkspaceDir>\.metadata\.log file there are the following messages:
!ENTRY org.eclipse.cdt.core 1 0 2024-10-14 10:30:17.365
!MESSAGE Indexed 'MIMXRT1064_Project' (20 sources, 43 headers) in 1,87 sec: 8.359 declarations; 17.870 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
While when there is my custom setting there are the following messages:
!ENTRY org.eclipse.cdt.core 4 0 2024-10-14 10:32:13.001
!MESSAGE Error: Cannot run program "..\compile.cmd": Launching failed
!STACK 0
java.io.IOException: Cannot run program "..\compile.cmd": Launching failed
	at org.eclipse.cdt.utils.spawner.Spawner.exec(Spawner.java:450)
	at org.eclipse.cdt.utils.spawner.Spawner.<init>(Spawner.java:147)
	at org.eclipse.cdt.utils.spawner.Spawner.<init>(Spawner.java:134)
	at org.eclipse.cdt.utils.spawner.ProcessFactory$Builder.start(ProcessFactory.java:273)
	at org.eclipse.cdt.utils.spawner.ProcessFactory.exec(ProcessFactory.java:366)
	at org.eclipse.cdt.core.CommandLauncher.execute(CommandLauncher.java:189)
	at org.eclipse.cdt.internal.core.BuildRunnerHelper.build(BuildRunnerHelper.java:274)
	at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runProgramForLanguage(AbstractBuiltinSpecsDetector.java:808)
	at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForLanguage(AbstractBuiltinSpecsDetector.java:736)
	at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForEachLanguage(AbstractBuiltinSpecsDetector.java:601)
	at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector$1.runInWorkspace(AbstractBuiltinSpecsDetector.java:527)
	at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:43)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY org.eclipse.cdt.core 1 0 2024-10-14 10:32:14.602
!MESSAGE Indexed 'MIMXRT1064_Project' (20 sources, 30 headers) in 1,05 sec: 7.246 declarations; 12.921 references; 18 unresolved inclusions; 59 syntax errors; 3.440 unresolved names (15%)
How can I try to remove the problem?
Many thanks
Biafra
9 回复数
3,677 次查看
Hello @biafra
Sorry I haven't received the file. Could you please send it again?
Alice
Alice
3,570 次查看
biafra
Hi @Alice_Yang,
Did you received the file?
Many thanks
Biafra
3,523 次查看
Hello @biafra
Yes, I have received it. I need to confirm with the IDE development team. I will reply to you as soon as possible. Thank you for your patience.
Alice
3,645 次查看
biafra
HI @Alice_Yang,
Sorry for the mistake, the file is attached.
Many thanks
Biafra
3,788 次查看
Hello @biafra
Could you please send your whole project with compile.cmd. I help to test and check on my side. Thanks.
Alice
3,762 次查看
biafra
Hi @Alice_Yang,
I did a step ahead.
If I set the command line to compile the project with the absolute path of compile.cmd file (C:/MyProject/compile.cmd), the unresolved inclusions decorations disappear.
So I tried to use the PROJECT_LOC path variable, but it seems it's not expanded and I have build errors too.
Is there a way to give the indexer a relative path to the compile.cmd file? Or even an absolute path depending on the project location?
I need the project location can be changed, because of different project developers drive path.
Many thanks
Biafra
2,866 次查看
biafra
Hi @Alice_Yang,
Now I'm able to configure an absolute path depending on the project localtion. It need to use the ProjDirPath path variable, as on this image:
However, the real project is a very complex project and the command line exceeds the 8191 character limit, so I cannot use the Windows .cmd batch file.
Because Git is installed on my PC, I can use a .sh shell file.
The file compile.sh is located in the project directory as compile.cmd and contains the following lines:
#!/bin/sh
arm-none-eabi-gcc $@
Although with compile.sh file the project is built with no errors, using a .sh file leads to the same problem: the indexer is not able to resolve lib include files.
Many thanks
Biafra
1,007 次查看
biafra
Hi @Alice_Yang,
Is there any news regarding the problem I reported?
Has it been verified from the development team?
In the meantime I switched to MCUXpresso 25.6, but nothing is changed.
Despite the error reported on the problems view, the project compiles fine.
Many thanks
Biafra
3,777 次查看
biafra
Hi @Alice_Yang,
Many thanks for your asnwer.
The project is attached. Let me know if you need something else.
Many thanks
Biafra
%3CLINGO-SUB%20id%3D%22lingo-sub-1973200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%9C%AA%E8%A7%A3%E5%86%B3%E7%9A%84%E7%BA%B3%E5%85%A5%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20MCUXpresso%2024.9%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E6%88%91%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%EF%BC%8C%E7%94%B1%E4%BA%8E%E6%9F%90%E4%BA%9B%E5%8E%9F%E5%9B%A0%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E7%BC%96%E8%AF%91%E5%99%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E3%80%82chenges%20%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%EF%BC%8C%E8%AF%A5%E9%A1%B9%E7%9B%AE%E7%9A%84%E7%89%88%E6%9C%AC%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E4%B9%9F%E6%9C%89%E5%89%AF%E4%BD%9C%E7%94%A8%EF%BC%9A%E7%B4%A2%E5%BC%95%E5%99%A8%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%20lib%20%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_0-1728895441980.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_0-1728895441980.png%22%20style%3D%22width%3A%20343px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304518iD5BAFCAAD336A647%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_0-1728895441980.png%22%20alt%3D%22biafra_0-1728895441980.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%B8%BA%E4%BA%86%E8%B0%83%E8%AF%95%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E9%80%89%E9%A1%B9%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%B5%8B%E8%AF%95%E7%A8%8B%E5%BA%8F%EF%BC%88%E6%96%B0%E9%A1%B9%E7%9B%AE-%26gt%3B%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E7%9A%84%20C%2FC%2B%2B%20%E9%A1%B9%E7%9B%AE%EF%BC%89%EF%BC%8C%E7%84%B6%E5%90%8E%E6%88%91%E5%B0%86%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%BB%8E%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%88%22%20Arm-none-eabi-gcc%20%22%EF%BC%89%E6%94%B9%E4%B8%BA%E5%B0%86%E9%A1%B9%E7%9B%AE%EF%BC%88%E9%A1%B9%E7%9B%AE%E5%B1%9E%E6%80%A7-%26gt%3B%20C%2FC%2B%2B%20%E7%89%88%E6%9C%AC-%26gt%3B%20%E8%AE%BE%E7%BD%AE-%26gt%3B%20MCU%20C%20%E7%BC%96%E8%AF%91%E5%99%A8%EF%BC%89%E4%BB%8E%E9%BB%98%E8%AE%A4%E5%80%BC%EF%BC%88%3CSPAN%3EArm-none-eabi-gcc%EF%BC%89%E7%BC%96%E8%AF%91%E4%B8%BA%20%22...%2Fcompile.cmd%20%22%3C%2FSPAN%3E%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_1-1728895775700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_1-1728895775700.png%22%20style%3D%22width%3A%20339px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304520iC55488A44640EDE5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_1-1728895775700.png%22%20alt%3D%22biafra_1-1728895775700.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%96%87%E4%BB%B6%20compile.cmd%20%E4%BD%8D%E4%BA%8E%E9%A1%B9%E7%9B%AE%E7%9B%AE%E5%BD%95%E4%B8%AD%EF%BC%8C%E5%8F%AA%E5%8C%85%E5%90%AB%E4%B8%80%E8%A1%8C%E5%86%85%E5%AE%B9%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3Earm-none-eabi-gcc%20%25*%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%AF%B9%E7%A8%8B%E5%BA%8F%E8%BF%9B%E8%A1%8C%E7%BC%96%E8%AF%91%EF%BC%8C%E7%A8%8B%E5%BA%8F%E4%BC%9A%E5%9C%A8%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E7%BB%93%E6%9D%9F%EF%BC%8C%E4%BD%86%E6%89%80%E6%9C%89%E7%9A%84%20c%20%E5%BA%93%E6%96%87%E4%BB%B6%E9%83%BD%E8%A2%AB%E9%AB%98%E4%BA%AE%E6%98%BE%E7%A4%BA%E4%B8%BA%E6%9C%AA%E8%A7%A3%E5%86%B3%E7%9A%84%E5%A4%B9%E6%9D%82%E7%89%A9%EF%BC%9A%E5%9B%A0%E6%AD%A4%E9%97%AE%E9%A2%98%E5%8F%AA%E5%87%BA%E5%9C%A8%E7%B4%A2%E5%BC%95%E5%99%A8%E4%B8%8A%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%E4%B8%8B%E6%B2%A1%E6%9C%89%E9%AB%98%E4%BA%AE%E6%98%BE%E7%A4%BA%EF%BC%8C%E5%9C%A8%3CWORKSPACEDIR%3E%5C.metadata%5C.log%20%E4%B8%AD%E4%B9%9F%E6%B2%A1%E6%9C%89%E9%AB%98%E4%BA%AE%E6%98%BE%E7%A4%BA%E3%80%82%E6%96%87%E4%BB%B6%E4%B8%AD%E6%9C%89%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FWORKSPACEDIR%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E!ENTRY%20org.eclipse.cdt.core%201%200%202024-10-14%2010%3A30%3A17.365%0A!MESSAGE%20Indexed%20'MIMXRT1064_Project'%20(20%20sources%2C%2043%20headers)%20in%201%2C87%20sec%3A%208.359%20declarations%3B%2017.870%20references%3B%200%20unresolved%20inclusions%3B%200%20syntax%20errors%3B%200%20unresolved%20names%20(0%25)%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E6%88%91%E8%BF%9B%E8%A1%8C%E8%87%AA%E5%AE%9A%E4%B9%89%E8%AE%BE%E7%BD%AE%E6%97%B6%EF%BC%8C%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BB%A5%E4%B8%8B%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E!ENTRY%20org.eclipse.cdt.core%204%200%202024-10-14%2010%3A32%3A13.001%0A!MESSAGE%20Error%3A%20Cannot%20run%20program%20%22..%5Ccompile.cmd%22%3A%20Launching%20failed%0A!STACK%200%0Ajava.io.IOException%3A%20Cannot%20run%20program%20%22..%5Ccompile.cmd%22%3A%20Launching%20failed%0A%09at%20org.eclipse.cdt.utils.spawner.Spawner.exec(Spawner.java%3A450)%0A%09at%20org.eclipse.cdt.utils.spawner.Spawner.%3CINIT%3E(Spawner.java%3A147)%0A%09at%20org.eclipse.cdt.utils.spawner.Spawner.%3CINIT%3E(Spawner.java%3A134)%0A%09at%20org.eclipse.cdt.utils.spawner.ProcessFactory%24Builder.start(ProcessFactory.java%3A273)%0A%09at%20org.eclipse.cdt.utils.spawner.ProcessFactory.exec(ProcessFactory.java%3A366)%0A%09at%20org.eclipse.cdt.core.CommandLauncher.execute(CommandLauncher.java%3A189)%0A%09at%20org.eclipse.cdt.internal.core.BuildRunnerHelper.build(BuildRunnerHelper.java%3A274)%0A%09at%20org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runProgramForLanguage(AbstractBuiltinSpecsDetector.java%3A808)%0A%09at%20org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForLanguage(AbstractBuiltinSpecsDetector.java%3A736)%0A%09at%20org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForEachLanguage(AbstractBuiltinSpecsDetector.java%3A601)%0A%09at%20org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector%241.runInWorkspace(AbstractBuiltinSpecsDetector.java%3A527)%0A%09at%20org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java%3A43)%0A%09at%20org.eclipse.core.internal.jobs.Worker.run(Worker.java%3A63)%0A%0A!ENTRY%20org.eclipse.cdt.core%201%200%202024-10-14%2010%3A32%3A14.602%0A!MESSAGE%20Indexed%20'MIMXRT1064_Project'%20(20%20sources%2C%2030%20headers)%20in%201%2C05%20sec%3A%207.246%20declarations%3B%2012.921%20references%3B%2018%20unresolved%20inclusions%3B%2059%20syntax%20errors%3B%203.440%20unresolved%20names%20(15%25)%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%A6%82%E4%BD%95%E5%B0%9D%E8%AF%95%E6%B6%88%E9%99%A4%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%AF%94%E5%A4%AB%E6%8B%89%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%89%E5%85%B3%E4%BA%8E%E6%88%91%E6%8A%A5%E5%91%8A%E7%9A%84%E9%97%AE%E9%A2%98%E7%9A%84%E6%B6%88%E6%81%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E5%B7%B2%E4%BB%8E%E5%BC%80%E5%8F%91%E5%9B%A2%E9%98%9F%E5%BE%97%E5%88%B0%E9%AA%8C%E8%AF%81%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E6%AD%A4%E6%9C%9F%E9%97%B4%EF%BC%8C%E6%88%91%E6%94%B9%E7%94%A8%E4%BA%86%20MCUXpresso%2025.6%EF%BC%8C%E4%BD%86%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%98%E5%8C%96%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_0-1757063945602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_0-1757063945602.png%22%20style%3D%22width%3A%20265px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F355742iBD9328AB42AEDFF5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_0-1757063945602.png%22%20alt%3D%22biafra_0-1757063945602.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_1-1757064191009.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_1-1757064191009.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F355745i1E84DB256B48916B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_1-1757064191009.png%22%20alt%3D%22biafra_1-1757064191009.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E5%9C%A8%E9%97%AE%E9%A2%98%E8%A7%86%E5%9B%BE%E4%B8%AD%E6%8A%A5%E5%91%8A%E4%BA%86%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%86%E9%A1%B9%E7%9B%AE%E7%BC%96%E8%AF%91%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%AF%94%E5%A4%AB%E6%8B%89%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2021867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2021867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E6%A0%B9%E6%8D%AE%E9%A1%B9%E7%9B%AE%E6%9C%AC%E5%9C%B0%E9%85%8D%E7%BD%AE%E7%BB%9D%E5%AF%B9%E8%B7%AF%E5%BE%84%E3%80%82%E5%AE%83%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20ProjDirPath%20%E8%B7%AF%E5%BE%84%E5%8F%98%E9%87%8F%EF%BC%8C%E5%A6%82%E5%9B%BE%E6%89%80%E7%A4%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_4-1735899636813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_4-1735899636813.png%22%20style%3D%22width%3A%20317px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318049i0D915975EDD8394F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_4-1735899636813.png%22%20alt%3D%22biafra_4-1735899636813.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%AE%9E%E9%99%85%E9%A1%B9%E7%9B%AE%E9%9D%9E%E5%B8%B8%E5%A4%8D%E6%9D%82%EF%BC%8C%E5%91%BD%E4%BB%A4%E8%A1%8C%E8%B6%85%E8%BF%87%E4%BA%86%208191%20%E4%B8%AA%E5%AD%97%E7%AC%A6%E7%9A%84%E9%99%90%E5%88%B6%EF%BC%8C%E5%9B%A0%E6%AD%A4%E6%88%91%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20Windows%20.cmd%E6%89%B9%E5%A4%84%E7%90%86%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E4%B8%BA%E6%88%91%E7%9A%84%E7%94%B5%E8%84%91%E4%B8%8A%E5%AE%89%E8%A3%85%E4%BA%86%20Git%3CSPAN%3E%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BD%BF%E7%94%A8%20.sh%20shell%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_2-1735899545460.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_2-1735899545460.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318047i2C895D1F85107802%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_2-1735899545460.png%22%20alt%3D%22biafra_2-1735899545460.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%96%87%E4%BB%B6%20compile.sh%20%E4%B8%8E%20compile.cmd%20%E4%B8%80%E6%A0%B7%E4%BD%8D%E4%BA%8E%E9%A1%B9%E7%9B%AE%E7%9B%AE%E5%BD%95%E4%B8%AD%EF%BC%8C%E5%8C%85%E5%90%AB%E4%BB%A5%E4%B8%8B%E5%87%A0%E8%A1%8C%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%23!%2Fbin%2Fsh%0Aarm-none-eabi-gcc%20%24%40%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E5%B0%BD%E7%AE%A1%E4%BD%BF%E7%94%A8%20compile.sh%20%E6%96%87%E4%BB%B6%E7%89%88%E6%9C%AC%E9%A1%B9%E7%9B%AE%E6%97%B6%E6%B2%A1%E6%9C%89%E9%94%99%E8%AF%AF%EF%BC%8C%E4%BD%86%E4%BD%BF%E7%94%A8%20.sh%E6%96%87%E4%BB%B6%E4%BC%9A%E5%AF%BC%E8%87%B4%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9A%3CSPAN%3E%E7%B4%A2%E5%BC%95%E5%99%A8%E6%97%A0%E6%B3%95%E8%A7%A3%E6%9E%90%20lib%20%E5%8C%85%E5%90%AB%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%AF%94%E5%A4%AB%E6%8B%89%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F65478%22%20target%3D%22_blank%22%3E%40biafra%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%88%91%E6%94%B6%E5%88%B0%E4%BA%86%E3%80%82%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%8E%20IDE%20%E5%BC%80%E5%8F%91%E5%9B%A2%E9%98%9F%E7%A1%AE%E8%AE%A4%E3%80%82%E6%88%91%E4%BC%9A%E5%B0%BD%E5%BF%AB%E7%BB%99%E6%82%A8%E5%9B%9E%E5%A4%8D%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%80%90%E5%BF%83%E7%AD%89%E5%BE%85%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%82%A8%E6%94%B6%E5%88%B0%E6%96%87%E4%BB%B6%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%AF%94%E5%A4%AB%E6%8B%89%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%8A%B1%E6%AD%89%E5%BC%84%E9%94%99%E4%BA%86%EF%BC%8C%E6%96%87%E4%BB%B6%E9%99%84%E5%90%8E%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%AF%94%E5%A4%AB%E6%8B%89%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F65478%22%20target%3D%22_blank%22%3E%40biafra%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%AF%B9%E4%B8%8D%E8%B5%B7%EF%BC%8C%E6%88%91%E8%BF%98%E6%B2%A1%E6%9C%89%E6%94%B6%E5%88%B0%E6%96%87%E4%BB%B6%E3%80%82%E6%82%A8%E8%83%BD%E5%86%8D%E5%8F%91%E4%B8%80%E6%AC%A1%E5%90%97%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%20%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1976013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1976013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%85%88%E8%A1%8C%E4%B8%80%E6%AD%A5%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%9C%A8%E5%91%BD%E4%BB%A4%E8%A1%8C%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%BC%96%E8%AF%91%E9%A1%B9%E7%9B%AE%E7%9A%84%E7%BB%9D%E5%AF%B9%E8%B7%AF%E5%BE%84%3C%2FSPAN%3E%3CSPAN%3E%E7%9A%84%E7%BB%9D%E5%AF%B9%E8%B7%AF%E5%BE%84%EF%BC%88C%3A%2FMyProject%2Fcompile.cmd%EF%BC%89%EF%BC%8C%E6%9C%AA%E8%A7%A3%E5%86%B3%E7%9A%84%E5%A4%B9%E6%9D%82%E8%A3%85%E9%A5%B0%E5%B0%B1%E4%BC%9A%E6%B6%88%E5%A4%B1%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%89%80%E4%BB%A5%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8PROJECT_LOC%E8%B7%AF%E5%BE%84%E5%8F%98%E9%87%8F%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BC%BC%E4%B9%8E%E6%B2%A1%E6%9C%89%E6%89%A9%E5%B1%95%EF%BC%8C%E6%88%91%E4%B9%9F%E6%9C%89%E7%89%88%E6%9C%AC%E9%94%99%E8%AF%AF%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%8A%9E%E6%B3%95%E7%BB%99%20%3C%2FSPAN%3E%E7%B4%A2%E5%BC%95%E5%99%A8%3CSPAN%3E%E6%8F%90%E4%BE%9B%20%3C%2FSPAN%3E%20%E7%BC%96%E8%AF%91.cmd%20%E6%96%87%E4%BB%B6%E7%9A%84%E7%9B%B8%E5%AF%B9%E8%B7%AF%E5%BE%84%EF%BC%9F%E7%94%9A%E8%87%B3%E6%98%AF%E7%BB%9D%E5%AF%B9%E8%B7%AF%E5%BE%84%EF%BC%88%E5%8F%96%E5%86%B3%E4%BA%8E%E9%A1%B9%E7%9B%AE%E4%BD%8D%E7%BD%AE%EF%BC%89%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%94%B1%E4%BA%8E%E9%A1%B9%E7%9B%AE%E5%BC%80%E5%8F%91%E4%BA%BA%E5%91%98%E7%9A%84%E9%A9%B1%E5%8A%A8%E8%B7%AF%E5%BE%84%E4%B8%8D%E5%90%8C%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E6%9B%B4%E6%94%B9%E9%A1%B9%E7%9B%AE%E4%BD%8D%E7%BD%AE%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%AF%94%E5%A4%AB%E6%8B%89%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1975990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1975990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%A5%E9%A1%B9%E7%9B%AE%E9%99%84%E5%90%8E%E3%80%82%E5%A6%82%E6%9E%9C%E8%BF%98%E9%9C%80%E8%A6%81%E4%BB%80%E4%B9%88%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%3C%2FP%3E%3CP%3E%E6%AF%94%E5%A4%AB%E6%8B%89%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1975984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1975984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F65478%22%20target%3D%22_blank%22%3E%40biafra%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%B0%86%E6%95%B4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E8%BF%9E%E5%90%8C%20compile.cmd%20%E4%B8%80%E8%B5%B7%E5%8F%91%E9%80%81%E7%BB%99%E6%88%91%E4%BB%AC%E3%80%82%E6%88%91%E5%B8%AE%E5%8A%A9%E6%88%91%E8%BF%99%E8%BE%B9%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%E5%92%8C%E6%A3%80%E6%9F%A5%E3%80%82%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E
