Unresolved inclusion
biafra
Senior Contributor I
Hi everyone,
I'm using MCUXpresso 24.9.
For some reasons in my project I needed to chnge the compiler command line. The chenges are working fine, the project is built without problem.
But there is a side effect: the indexer is not able to resolve lib include files:
To debug the problem I created a test program with the default options (New Project -> Create a new C/C++ project), then I changed the command line to compile the project (Project properties -> C/C++ Build -> Settings -> MCU C compiler) from the default value ("arm-none-eabi-gcc") to "../compile.cmd":
The file compile.cmd is located in the project directory and contains the single line:
arm-none-eabi-gcc %*
If I compile the program the process is terminated without errors, but all the c library files are highlighted as unresolved inclusions: so the problem belongs only to the indexer.
When there is the default setting no highlight is present and in the <WorkspaceDir>\.metadata\.log file there are the following messages:
!ENTRY org.eclipse.cdt.core 1 0 2024-10-14 10:30:17.365
!MESSAGE Indexed 'MIMXRT1064_Project' (20 sources, 43 headers) in 1,87 sec: 8.359 declarations; 17.870 references; 0 unresolved inclusions; 0 syntax errors; 0 unresolved names (0%)
While when there is my custom setting there are the following messages:
!ENTRY org.eclipse.cdt.core 4 0 2024-10-14 10:32:13.001
!MESSAGE Error: Cannot run program "..\compile.cmd": Launching failed
!STACK 0
java.io.IOException: Cannot run program "..\compile.cmd": Launching failed
	at org.eclipse.cdt.utils.spawner.Spawner.exec(Spawner.java:450)
	at org.eclipse.cdt.utils.spawner.Spawner.<init>(Spawner.java:147)
	at org.eclipse.cdt.utils.spawner.Spawner.<init>(Spawner.java:134)
	at org.eclipse.cdt.utils.spawner.ProcessFactory$Builder.start(ProcessFactory.java:273)
	at org.eclipse.cdt.utils.spawner.ProcessFactory.exec(ProcessFactory.java:366)
	at org.eclipse.cdt.core.CommandLauncher.execute(CommandLauncher.java:189)
	at org.eclipse.cdt.internal.core.BuildRunnerHelper.build(BuildRunnerHelper.java:274)
	at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runProgramForLanguage(AbstractBuiltinSpecsDetector.java:808)
	at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForLanguage(AbstractBuiltinSpecsDetector.java:736)
	at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForEachLanguage(AbstractBuiltinSpecsDetector.java:601)
	at org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector$1.runInWorkspace(AbstractBuiltinSpecsDetector.java:527)
	at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:43)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
!ENTRY org.eclipse.cdt.core 1 0 2024-10-14 10:32:14.602
!MESSAGE Indexed 'MIMXRT1064_Project' (20 sources, 30 headers) in 1,05 sec: 7.246 declarations; 12.921 references; 18 unresolved inclusions; 59 syntax errors; 3.440 unresolved names (15%)
How can I try to remove the problem?
Many thanks
Biafra
Hello @biafra
Sorry I haven't received the file. Could you please send it again?
Alice
Alice
biafra
Hi @Alice_Yang,
Did you received the file?
Many thanks
Biafra
Hello @biafra
Yes, I have received it. I need to confirm with the IDE development team. I will reply to you as soon as possible. Thank you for your patience.
Alice
biafra
HI @Alice_Yang,
Sorry for the mistake, the file is attached.
Many thanks
Biafra
Hello @biafra
Could you please send your whole project with compile.cmd. I help to test and check on my side. Thanks.
Alice
biafra
Hi @Alice_Yang,
I did a step ahead.
If I set the command line to compile the project with the absolute path of compile.cmd file (C:/MyProject/compile.cmd), the unresolved inclusions decorations disappear.
So I tried to use the PROJECT_LOC path variable, but it seems it's not expanded and I have build errors too.
Is there a way to give the indexer a relative path to the compile.cmd file? Or even an absolute path depending on the project location?
I need the project location can be changed, because of different project developers drive path.
Many thanks
Biafra
biafra
Hi @Alice_Yang,
Now I'm able to configure an absolute path depending on the project localtion. It need to use the ProjDirPath path variable, as on this image:
However, the real project is a very complex project and the command line exceeds the 8191 character limit, so I cannot use the Windows .cmd batch file.
Because Git is installed on my PC, I can use a .sh shell file.
The file compile.sh is located in the project directory as compile.cmd and contains the following lines:
#!/bin/sh
arm-none-eabi-gcc $@
Although with compile.sh file the project is built with no errors, using a .sh file leads to the same problem: the indexer is not able to resolve lib include files.
Many thanks
Biafra
biafra
Hi @Alice_Yang,
Is there any news regarding the problem I reported?
Has it been verified from the development team?
In the meantime I switched to MCUXpresso 25.6, but nothing is changed.
Despite the error reported on the problems view, the project compiles fine.
Many thanks
Biafra
biafra
Hi @Alice_Yang,
Many thanks for your asnwer.
The project is attached. Let me know if you need something else.
Many thanks
Biafra
%3CLINGO-SUB%20id%3D%22lingo-sub-1973200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUnresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1973200%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20everyone%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI'm%20using%20MCUXpresso%2024.9.%3C%2FP%3E%3CP%3EFor%20some%20reasons%20in%20my%20project%20I%20needed%20to%20chnge%20the%20compiler%26nbsp%3Bcommand%20line.%20The%20chenges%20are%20working%20fine%2C%20the%20project%20is%20built%20without%20problem.%3C%2FP%3E%3CP%3EBut%20there%20is%20a%20side%20effect%3A%20the%20indexer%20is%20not%20able%20to%20resolve%20lib%20include%20files%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_0-1728895441980.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_0-1728895441980.png%22%20style%3D%22width%3A%20343px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304518iD5BAFCAAD336A647%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_0-1728895441980.png%22%20alt%3D%22biafra_0-1728895441980.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ETo%20debug%20the%20problem%20I%20created%20a%20test%20program%20with%20the%20default%20options%20(New%20Project%20-%26gt%3B%20Create%20a%20new%20C%2FC%2B%2B%20project)%2C%20then%20I%20changed%20the%20command%20line%20to%20compile%20the%20project%20(Project%20properties%20-%26gt%3B%20C%2FC%2B%2B%20Build%20-%26gt%3B%20Settings%20-%26gt%3B%20MCU%20C%20compiler)%20from%20the%20default%20value%20(%22%3CSPAN%3Earm-none-eabi-gcc%22)%20to%20%22..%2Fcompile.cmd%22%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_1-1728895775700.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_1-1728895775700.png%22%20style%3D%22width%3A%20339px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F304520iC55488A44640EDE5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_1-1728895775700.png%22%20alt%3D%22biafra_1-1728895775700.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20file%20compile.cmd%20is%20located%20in%20the%20project%20directory%20and%20contains%20the%20single%20line%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3Earm-none-eabi-gcc%20%25*%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3CP%3EIf%20I%20compile%20the%20program%20the%20process%20is%20terminated%20without%20errors%2C%20but%20all%20the%20c%20library%20files%20are%20highlighted%20as%20unresolved%20inclusions%3A%20so%20the%20problem%20belongs%20only%20to%20the%20indexer.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EWhen%20there%20is%20the%20default%20setting%20no%20highlight%20is%20present%20and%20in%20the%20%3CWORKSPACEDIR%3E%5C.metadata%5C.log%20file%20there%20are%20the%20following%20messages%3A%3C%2FWORKSPACEDIR%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E!ENTRY%20org.eclipse.cdt.core%201%200%202024-10-14%2010%3A30%3A17.365%0A!MESSAGE%20Indexed%20'MIMXRT1064_Project'%20(20%20sources%2C%2043%20headers)%20in%201%2C87%20sec%3A%208.359%20declarations%3B%2017.870%20references%3B%200%20unresolved%20inclusions%3B%200%20syntax%20errors%3B%200%20unresolved%20names%20(0%25)%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EWhile%20when%20there%20is%20my%20custom%20setting%20there%20are%20the%20following%20messages%3A%3C%2FP%3E%3CBR%20%2F%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E!ENTRY%20org.eclipse.cdt.core%204%200%202024-10-14%2010%3A32%3A13.001%0A!MESSAGE%20Error%3A%20Cannot%20run%20program%20%22..%5Ccompile.cmd%22%3A%20Launching%20failed%0A!STACK%200%0Ajava.io.IOException%3A%20Cannot%20run%20program%20%22..%5Ccompile.cmd%22%3A%20Launching%20failed%0A%09at%20org.eclipse.cdt.utils.spawner.Spawner.exec(Spawner.java%3A450)%0A%09at%20org.eclipse.cdt.utils.spawner.Spawner.%3CINIT%3E(Spawner.java%3A147)%0A%09at%20org.eclipse.cdt.utils.spawner.Spawner.%3CINIT%3E(Spawner.java%3A134)%0A%09at%20org.eclipse.cdt.utils.spawner.ProcessFactory%24Builder.start(ProcessFactory.java%3A273)%0A%09at%20org.eclipse.cdt.utils.spawner.ProcessFactory.exec(ProcessFactory.java%3A366)%0A%09at%20org.eclipse.cdt.core.CommandLauncher.execute(CommandLauncher.java%3A189)%0A%09at%20org.eclipse.cdt.internal.core.BuildRunnerHelper.build(BuildRunnerHelper.java%3A274)%0A%09at%20org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runProgramForLanguage(AbstractBuiltinSpecsDetector.java%3A808)%0A%09at%20org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForLanguage(AbstractBuiltinSpecsDetector.java%3A736)%0A%09at%20org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector.runForEachLanguage(AbstractBuiltinSpecsDetector.java%3A601)%0A%09at%20org.eclipse.cdt.managedbuilder.language.settings.providers.AbstractBuiltinSpecsDetector%241.runInWorkspace(AbstractBuiltinSpecsDetector.java%3A527)%0A%09at%20org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java%3A43)%0A%09at%20org.eclipse.core.internal.jobs.Worker.run(Worker.java%3A63)%0A%0A!ENTRY%20org.eclipse.cdt.core%201%200%202024-10-14%2010%3A32%3A14.602%0A!MESSAGE%20Indexed%20'MIMXRT1064_Project'%20(20%20sources%2C%2030%20headers)%20in%201%2C05%20sec%3A%207.246%20declarations%3B%2012.921%20references%3B%2018%20unresolved%20inclusions%3B%2059%20syntax%20errors%3B%203.440%20unresolved%20names%20(15%25)%3C%2FINIT%3E%3C%2FINIT%3E%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EHow%20can%20I%20try%20to%20remove%20the%20problem%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMany%20thanks%3C%2FP%3E%3CP%3EBiafra%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164314%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIs%20there%20any%20news%20regarding%20the%20problem%20I%20reported%3F%3C%2FP%3E%3CP%3EHas%20it%20been%20verified%20from%20the%20development%20team%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIn%20the%20meantime%20I%20switched%20to%20MCUXpresso%2025.6%2C%20but%20nothing%20is%20changed.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_0-1757063945602.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_0-1757063945602.png%22%20style%3D%22width%3A%20265px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F355742iBD9328AB42AEDFF5%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_0-1757063945602.png%22%20alt%3D%22biafra_0-1757063945602.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_1-1757064191009.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_1-1757064191009.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F355745i1E84DB256B48916B%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_1-1757064191009.png%22%20alt%3D%22biafra_1-1757064191009.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDespite%20the%20error%20reported%20on%20the%20problems%20view%2C%20the%20project%20compiles%20fine.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMany%20thanks%3C%2FP%3E%3CP%3EBiafra%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2021867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2021867%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ENow%20I'm%20able%20to%20configure%20an%20absolute%20path%20depending%20on%20the%20project%20localtion.%20It%20need%20to%20use%20the%26nbsp%3BProjDirPath%20path%20variable%2C%20as%20on%20this%20image%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_4-1735899636813.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_4-1735899636813.png%22%20style%3D%22width%3A%20317px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318049i0D915975EDD8394F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_4-1735899636813.png%22%20alt%3D%22biafra_4-1735899636813.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EHowever%2C%20the%20real%20project%20is%20a%20very%20complex%20project%20and%20the%20command%20line%20exceeds%20the%208191%20character%20limit%2C%20so%20I%20cannot%20use%20the%20Windows%20.cmd%20batch%20file.%3C%2FP%3E%3CP%3EBecause%20Git%20is%20installed%20on%20my%20PC%3CSPAN%3E%2C%20I%20can%20use%20a%20.sh%20shell%20file.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22biafra_2-1735899545460.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22biafra_2-1735899545460.png%22%20style%3D%22width%3A%20318px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F318047i2C895D1F85107802%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22biafra_2-1735899545460.png%22%20alt%3D%22biafra_2-1735899545460.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EThe%20file%20compile.sh%20is%20located%20in%20the%20project%20directory%20as%20compile.cmd%20and%20contains%20the%20following%20lines%3A%3C%2FSPAN%3E%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E%23!%2Fbin%2Fsh%0Aarm-none-eabi-gcc%20%24%40%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3EAlthough%20with%20compile.sh%20file%20the%20project%20is%20built%20with%20no%20errors%2C%26nbsp%3Busing%20a%20.sh%20file%20leads%20to%20the%20same%20problem%3A%26nbsp%3B%3CSPAN%3Ethe%20indexer%20is%20not%20able%20to%20resolve%20lib%20include%20files.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMany%20thanks%3C%2FP%3E%3CP%3EBiafra%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F65478%22%20target%3D%22_blank%22%3E%40biafra%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EYes%2C%20I%20have%20received%20it.%20I%20need%20to%20confirm%20with%20the%20IDE%20development%20team.%20I%20will%20reply%20to%20you%20as%20soon%20as%20possible.%20Thank%20you%20for%20your%20patience.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1991167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1991167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDid%20you%20received%20the%20file%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMany%20thanks%3C%2FP%3E%3CP%3EBiafra%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1982151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1982151%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHI%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ESorry%20for%20the%20mistake%2C%20the%20file%20is%20attached.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMany%20thanks%3C%2FP%3E%3CP%3EBiafra%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1979980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1979980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F65478%22%20target%3D%22_blank%22%3E%40biafra%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESorry%20I%20haven't%20received%20the%20file.%20Could%20you%20please%20send%20it%20again%3F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EAlice%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1976013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1976013%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20did%20a%20step%20ahead.%3C%2FP%3E%3CP%3E%3CSPAN%3EIf%20I%20set%20the%20command%20line%20to%20compile%20the%20project%20with%20the%20absolute%20path%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3Bof%20compile.cmd%20file%20(C%3A%2FMyProject%2Fcompile.cmd)%2C%20the%20unresolved%20inclusions%20decorations%20disappear.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ESo%20I%20tried%20to%20use%20the%20PROJECT_LOC%20path%20variable%2C%20but%20it%20seems%20it's%20not%20expanded%20and%20I%20have%20build%20errors%20too.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EIs%20there%20a%20way%20to%20give%26nbsp%3B%3C%2FSPAN%3Ethe%20indexer%26nbsp%3B%3CSPAN%3Ea%20relative%20path%20to%20the%20compile.cmd%20file%3F%20Or%20even%20an%20absolute%20path%20depending%20on%20the%20project%20location%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EI%20need%20the%20project%20location%20can%20be%20changed%2C%20because%20of%20different%20project%20developers%20drive%20path.%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EMany%20thanks%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EBiafra%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1975990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1975990%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F27788%22%20target%3D%22_blank%22%3E%40Alice_Yang%3C%2FA%3E%2C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMany%20thanks%20for%20your%20asnwer.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThe%20project%20is%20attached.%20Let%20me%20know%20if%20you%20need%20something%20else.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EMany%20thanks%3C%2FP%3E%3CP%3EBiafra%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1975984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unresolved%20inclusion%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1975984%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F65478%22%20target%3D%22_blank%22%3E%40biafra%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3ECould%20you%20please%20send%20your%20whole%20project%20with%20compile.cmd.%20I%20help%20to%20test%20and%20check%20on%20my%20side.%20Thanks.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EAlice%3C%2FP%3E%3C%2FLINGO-BODY%3E
