Unresolved inclusion: <stdio.h>
35,159 次查看
shauldorf
While importing project from MCUXpresso 10.3.1 to new IDE v. 11.0.0
I got question mark  ? Unresolved inclusion: <stdio.h>
34,427 次查看
shauldorf
Hello Erich,
As usual you are in the right moment.
Thanks to you and Alexis .
Shaul
6 回复数
34,429 次查看
lpcxpresso_supp
Using the Tools->Fixup Parsers option on the Project Properties view's context sensitive menu (with the affect project selected) should resolve this issue for you.
[ This issue is described in the release info at: MCUXpresso IDE v11.0.0 Now Available ]
MCUXpresso IDE Support
34,426 次查看
shauldorf
Can you be more specific I can't fined
In Project Properties view's.
Where this issue is described in release info exactly?
34,426 次查看
Alexis_A
Hi shauldorf‌,
You can find it here:
Alexis Andalon
34,426 次查看
shauldorf
From yours screen I don't know to which menu his "Tools" belongs.
I'm not familiar with Eclipse perspective options and I'm using standard Menu Bar.
Sorry
Shaul
34,424 次查看
BlackNight
Hi Shaul,
it is in the context menu: select your project, then mouse right-click on it to get the menu.
I hope this helps,
Erich
34,428 次查看
shauldorf
Hello Erich,
Shaul
