Unable to set cluster value in ZBPro Configuration Editor in MCUXpresso
anthony_r_myers
I'm trying to add a TemperatureMeasurement cluster to a JN5189 project using the ZigBee Pro (ZBPro) Configuration Editor in MCUXpresso, but I'm unable to set the cluster value to 0x0402.  As soon as I enter a value, then leave the text box, the value resets to 0x0000.  I've tried pressing Enter and Tab to get it to accept the change, but nothing seems to work.  Am I doing something wrong, or is anyone else seeing the same behavior?
mario_castaneda
I already reported this issue, we are working on this.
In the meantime, you could modify this value using a text editor.
Sorry for any inconvenience that this may cause you.
Mario
mario_castaneda
Hi Anthony,
I reproduced this issue. I am checking this and I will get back to you as soon as possible.
Mario
