I have been working with KDS 3.2. I ported to MCUX. It builds and runs OK but I noticed Embsys registers doesn't support the KV58. I am using org.eclipse.cdt.embsysregview_0.2.6.jar
So specifically I'd like to know if there is EmbSys support. And in general, what's the feeling for going to MCUX for the KV58. Should I stay with KDS?
Joe
Solved! Go to Solution.
Hi Joe,
The EmbSysRegView plugin currently cannot be used in Eclipse Neon (MCUXpresso is Eclipse Neon based, the latest Eclipse today).
But you don’t need that one, because MCUxpresso IDE has the Peripherals+ view, see
You have to clock the peripheral in order see its values.Otherwise the Register value will be empty.
Jennie Zhang
Hi Joe,
Our recommended IDE for KV58 is MCUXpresso IDE.
But KDS is also available for KV58, if EmbSysRegView doesn't support it, I suggest you refer this article to add KV58 to EmbSys Registers.
Adding a new chip to Embsys Registers.
Jennie Zhang
Thank you for your reply.
The article you referenced is for KDS. MCUX doesn't follow the same directory format.
Can you provide instructions for adding a chip to EmbSys on MCUX?
Joe
Hi Joe,
Jennie Zhang
