I'm looking to download an SDK that supports the TWR-SER module (particularly the ethernet interface on that module) but am struggling, please can you help?
If it matters, the host board in the tower system is a K64F120M
thanks
-Nick
I believe this TWR module itself might not be fully supported by our current SDKs. I checked the KSDK as well but found nothing either.
However, you should be able to import the MK64 ethernet drivers and use them without problems on your TWR module.
Edwin.
I am using the same PHI KSZ8041NL on my prototype with MK64. The FRDM-K64 board uses KSZ8081 PHY. Please advise how can I import the drivers from SDK to use for KSZ8041NL PHY?
Thank you,
FS
