Not quite sure how to set up freeRTOS' heap config. The MCUXpresso examples show configTOTAL_HEAP_SIZE set to (10 * 1024) Though the QN9090 has total of 152kByte, managed by two separate AHB ports, one section of 88k another of 64kByte size.
So how should I configure configTOTAL_HEAP_SIZE ? Can it be at least the size of 88kByte? Can freeRTOS utilize the two different SRAM sections? How?
Solved! Go to Solution.
Nevuh-mind, saw this beautiful article on heap5: https://mcuoneclipse.com/2017/09/18/using-multiple-memory-regions-with-the-freertos-heap/
