Probes discovered window width or Available attached probes columns width
935件の閲覧回数
piotr_kolodziej
I do flashing with "GUI Flash Tool" often with MCUXpresso and I need to select one of several connected boards.
Would it be possible to have any of the following features:
1. Save "Probes discovered" window size or change it's default width in any of the *.xml config files?
2. Save manually changed or automatically calculate "Available attached probes" columns width?
Piotr
4 返答(返信)
854件の閲覧回数
piotr_kolodziej
Hi Erich,
Thx for good news.
Enough would be to know what to enter and in which .metadata\.plugins xml config file.
Best,
Piotr
853件の閲覧回数
ErichStyger
Senior Contributor V
To my understanding, these values are not stored anywhere (for now).
854件の閲覧回数
piotr_kolodziej
I had a hope these values are not stored but perhaps are read if available in config file.
It is OK, only one additional double click before each flashing.
853件の閲覧回数
ErichStyger
Hi Piotr,
if I remember correctly, I had filed a ticket exactly on this. So hopefully this might be implemented in a future release.
