Probes discovered window width or Available attached probes columns width
piotr_kolodziej
I do flashing with "GUI Flash Tool" often with MCUXpresso and I need to select one of several connected boards.
Would it be possible to have any of the following features:
1. Save "Probes discovered" window size or change it's default width in any of the *.xml config files?
2. Save manually changed or automatically calculate "Available attached probes" columns width?
Piotr
piotr_kolodziej
Hi Erich,
Thx for good news.
Enough would be to know what to enter and in which .metadata\.plugins xml config file.
Best,
Piotr
ErichStyger
Specialist I
To my understanding, these values are not stored anywhere (for now).
piotr_kolodziej
I had a hope these values are not stored but perhaps are read if available in config file.
It is OK, only one additional double click before each flashing.
ErichStyger
Specialist I
Hi Piotr,
if I remember correctly, I had filed a ticket exactly on this. So hopefully this might be implemented in a future release.
