Out Of Box Binary?
Search instead for
Out Of Box Binary?
krisztiannagy
Where can I find the original out of box firmware? Binary is absolutely enough for me.
Krisztian
brendonslade
The original binary in the board is a TouchGFX demo. We have it posted under the Downloads tab of the board page: http://nxp.com/demoboard/om13092
There is also the sprinkler/irrigation demo there plus instructions on how to flash the demo.
The current instructions recommend flashing your debug probe with the J-link image to program the demo, then using SEGGER's J-flasher lite utility. We'll plan to get binary version of the images later so you can also use MCUXpresso IDE's flashing utility, available in the IDE.
Unfortunately we have a temporary issue with the link but are working to correct it now, and it should be up and working within an hour or so.
[UPDATE: content is now working/available :-)]
Brendon
brendonslade
Brendon
sleroy
Has the the sprinkler/irrigation demo been taken down or is it still available?
brendonslade
We are no longer working with this graphics partner, so it is no longer posted. We recommend you evaluate SEGGER emWIN (included in our MCUXpresso SDK) or TARA's Embedded Wizard instead.
https://www.nxp.com/video/embedded-wizard-for-lpc546xx-webinar:EMBEDDED-WIZARD-FOR-LPC546XX
https://www.embedded-wizard.de/platforms/nxp/lpc546xx/
We have new demo with TARA that also uses AWS cloud connectivity that we will be releasing in the next few months.
krisztiannagy
Hi all,
Thanks for your support! I flashed the board with the original demo binary with SEGGER's utility.
I learned how works the MCUXpresso IDE and Segger's Flasher Utility. I'll communicate this to my customers.
Krisztian
radomirkozub-re
What dev. board?
krisztiannagy
OM13092, LPCXpresso54608. I found the latest sprinkler demo I burnt easily and working fine, but I'd like to use the factory one.
Thanks.
radomirkozub-re
I didn't find yet, let me figure out....
pavel_sadek
today we are showing the IDE and its integration, not intended to flash the binaries
Pavel
krisztiannagy
Hello Pavel,
Thanks for your reply. From my side everything is working fine. How could help me to get the original flash content? I'd like to demoing this board to my customers with the original demo.
Thanks.
Krisztian
