MCUXpresso hangs on startup after laptop crash
hfuhruhurr
Hi there,
I'm using MXUXpresso 11.5 on an older project with a LPC1768 process (actually, it's a project with 3 subprojects).
My computer crashed today while MCUX was open but idling. After restarting the computer, MCUXpresso starts up, shows the IDE (full screen, code is displayed, even with correct highlighting of compiler switches) but then freezes.
Is there any condition which has to be removed (clean lock files or folders, workspace ...) that helps?
Rainer
hfuhruhurr
I managed to revive it by replacing the workspace folder contents with the ones from a recent backup.
I'd still be interested in a solution (or at least background information on the problem).
hfuhruhurr
I stated: The IDE shows up, displays code but then freezes.
I can't clean, refresh or build anything.
I don't think this will be resolved, here, let's just forget about it.
Rainer
hfuhruhurr
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, this is difficult to replay, is not really an issue from the IDE, it was a problem for the bad shutdown. Before replacing the workspace did you try to clean, refresh and build again?
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-1960845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXpresso%20hangs%20on%20startup%20after%20laptop%20crash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960845%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20there%2C%3C%2FP%3E%3CP%3EI'm%20using%20MXUXpresso%2011.5%20on%20an%20older%20project%20with%20a%20LPC1768%20process%20(actually%2C%20it's%20a%20project%20with%203%20subprojects).%3C%2FP%3E%3CP%3EMy%20computer%20crashed%20today%20while%20MCUX%20was%20open%20but%20idling.%20After%20restarting%20the%20computer%2C%20MCUXpresso%20starts%20up%2C%20shows%20the%20IDE%20(full%20screen%2C%20code%20is%20displayed%2C%20even%20with%20correct%20highlighting%20of%20compiler%20switches)%20but%20then%20freezes.%3C%2FP%3E%3CP%3EIs%20there%20any%20condition%20which%20has%20to%20be%20removed%20(clean%20lock%20files%20or%20folders%2C%20workspace%20...)%20that%20helps%3F%3C%2FP%3E%3CP%3EBest%20regards%3C%2FP%3E%3CP%3ERainer%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1961349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20hangs%20on%20startup%20after%20laptop%20crash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961349%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20stated%3A%20The%20IDE%20shows%20up%2C%20displays%20code%20but%20then%20freezes.%3C%2FP%3E%3CP%3EI%20can't%20clean%2C%20refresh%20or%20build%20anything.%3C%2FP%3E%3CP%3EI%20don't%20think%20this%20will%20be%20resolved%2C%20here%2C%20let's%20just%20forget%20about%20it.%3C%2FP%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3ERainer%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1961143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20hangs%20on%20startup%20after%20laptop%20crash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1961143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%20my%20name%20is%20Pavel%2C%20and%20I%20will%20be%20supporting%20your%20case%2C%20this%20is%20difficult%20to%20replay%2C%20is%20not%20really%20an%20issue%20from%20the%20IDE%2C%20it%20was%20a%20problem%20for%20the%20bad%20shutdown.%20Before%20replacing%20the%20workspace%20did%20you%20try%20to%20clean%2C%20refresh%20and%20build%20again%3F%3C%2FP%3E%0A%3CP%3EBest%20regards%2C%3CBR%20%2F%3EPavel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1960886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCUXpresso%20hangs%20on%20startup%20after%20laptop%20crash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1960886%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20managed%20to%20revive%20it%20by%20replacing%20the%20workspace%20folder%20contents%20with%20the%20ones%20from%20a%20recent%20backup.%3C%2FP%3E%3CP%3EI'd%20still%20be%20interested%20in%20a%20solution%20(or%20at%20least%20background%20information%20on%20the%20problem).%3C%2FP%3E%3C%2FLINGO-BODY%3E
