This post was created to help Linux new adopters to install MCUXpresso without command lines. it is a simple, fast and clean way to install the MCUXpresso on your linux machine. I have used the Mint KDE to create this example:
1. download the MCUXpresso (Linux version from nxp.com website - https://freescaleesd.flexnetoperations.com/337170/897/12189897/mcuxpressoide-10.1.0_589.x86_64.deb.b...
2. Open the file manager (in my case Dolphin) and clicking with right botton of your mouse on
mcuxpressoide-10.1.0_589.x86_64.deb.bin file, go to Permissions in properties window and set file as executable:
3. Clicking again with right mouse botton on the .bin file go to "open with" >> "Others" and write on search box "gksu" and run:
4. From this step onwards, you need only to follow normal instalation process, and finally run the MCUXpresso.
