I am not sure here is right place to announce, but I think this is valuable to announce publicly.
Sometimes I fall into a situation that MCUXpresso IDE always stucked and "Not Responding" is displayed no matter how many times I try to launch it.
I can do nothing but kill the process.
I found that deleting "workspace\.metadata\.plugins\org.eclipse.e4.workbench\workbench.xmi" solves the problem though it will reset workbench.
I think this is a bug of Eclipse??
解決済! 解決策の投稿を見る。
I think it is the same issue as I have documented here:
https://mcuoneclipse.com/2017/10/02/how-to-fix-an-eclipse-workspace-that-does-not-open-any-more/
Probably you have a view with a problem open in your perspective causing it.
You could try to identify the culprit if you close some views?
I hope this helps,
Erich
Thank you, @Tomoki_Kimura :-).
I hope this helps,
Erich
Hi, @ErichStyger
Oh, it looks like my situation. I didn't notice some views is blocking startup.
By the way, I often see your article on "MCU on Eclipse".
"Position-Independent Code with GCC for ARM Cortex-M" was great article!
Thanks!
