MCUXpresso IDE Expressions view issue
gschelotto
I think this is an issue in the latest version of MCUXpresso IDE (v11.1.0). In the Expression view I can see the value for a float variable but only in the float format. I'm not able to see this value in Decimal, Hex, Binary or Octal as their values are zero. However I'm able to see the value from the Memory view as shown.
please, can anybody confirm this?
regards,
gaston
gschelotto
I'm puzzled. Now everything works as expected and I'm not able to reproduce the previous error.
gaston
lpcxpresso_supp
Do you see the same issue if you use the "Global Variables" view ?
MCUXpresso IDE Support
