MCUXpresso ERROR:StubMonSemihost
898 次查看
Yuan1
Everything went well when I compiled the program in GUI GUIDER, but after importing the file into MCUXpresso, the following problems were displayed when debugging Error in final launch sequence: Failed to execute MI command: StubMonSemihost: -interpreter-exec console "mon semihost enable"Error message from debugger back end: "monitor" command not supported by this target. Failed to execute MI command: StubMonSemihost: -interpreter-exec console "mon semihost enable"Error message from debugger back end: "monitor" command not supported by this target. "monitor" command not supported by this target. I try change its SDK Debug console,and re-install mcuxpresso. by a pity College Students
886 次查看
Yuan1
sorry for the typesetting,here is the new one
882 次查看
lpcxpresso_supp
Please attach the logs (Help => MCUXpresso IDE Save Info for Support)...
MCUXpresso IDE Support
