I am seeing a triple repeat of the columns for the single global variable I am tracing.
Can your provide any more details of how to reproduce?
For instance, what debug probe and target MCU are you using?
Does this happen every time you debug and display the global?
Does it happen with other globals? And with other projects?
What do you see if you choose to display the details of your globals as a plot or "Number Formats Viewer"?
Please can you also generate a log file for us to look at in case this provides any clues...
It might also be useful if you could copy/paste the text from the gdb-traces entry in the Console View into a text file and attach that too.
MCUXpresso IDE Support
