I'm still not able to select Kinetis K27F middleware packages from MCUXpresso SDK Management (10.x/11.0 and SDK 2.5/2.6). According to a NXP response of the post below, there is a problem with the SDK for Kinetis K27. It was supposed to be fixed in SDK 2.6, but it is not. Can anyone from NXP please comment? When will this be fixed ?
Ref :
MCUXpresso 10.3 and SDK Management problem | NXP Community
Eldar
Solved! Go to Solution.
This issue maybe fixed in SDK 2.7 version according to schedule.
Hi Eldar
This issue still exists in SDK2.6. Let me check with soft team and get it back to you when I have results.
Thank you, it now works as expected.
By the way, I had to change the MCU type for all my projects from MK27FN2M0xxx15 (obsolete) to MK27FN2M0Axxx15 in order for this to work.
