MCU-Link on MCUXpresso not detected
arnogir
Senior Contributor II
HEllo
I'm testing the MCU-Link on MCUXpresso v11.7.
(I never used this probe before)
Probe is updated with new firmware like indicated:
But when I want detect probe, this is soloog and I have java error
Is somebody can indicate to me what I'm forget?
arnogir
Hello
WIth MCUXpresso v11.6.1 this work...
So, wait v11.8...
Thank for your help
p3
No extra plug-ins or drivers should be needed for MCU-Link.
I would recommend trying MCUXpresso 11.6.  You will have to downgrade the MCU-Link firmware to 2.263.  I only started having these types of issues with MCUXpresso 11.7.  I have used 11.4, 11.5, and 11.6 without issues over the last few years but now 11.7 is having problems.  If 11.6 does work, then maybe wait for 11.8 to drop in July.
Peter
p3
  1. Unplug all other probes but MCU-Link.
  2. Shutdown all instances of MCUXpresso.  Check in Windows Task Manager for zombie mcuxpresso processes (very often I have them). Or you can restart Windows.
  3. Open MCUXpresso and your project.
  4. Hold SHIFT key while pressing Debug to scan for new probes.
That will give you the best chance of it working.  Make sure your target has power or you will get the ACK error.
arnogir
I tried without success.
I obtain now the follwoing messages after about 1 or 2 minutes of research...
Any other Idea?
Should I install other plugins in more than the normal installation of MCUXpresso?
Installation details:
Binaries path: C:\nxp\MCUXpressoIDE_11.7.0_9198\ide\plugins\com.nxp.mcuxpresso.tools.bin.win32_11.7.0.202301121712\binaries\
Tools path: C:\nxp\MCUXpressoIDE_11.7.0_9198\ide\plugins\com.nxp.mcuxpresso.tools.win32_11.7.0.202209140929\tools\
Wizards path: C:\nxp\MCUXpressoIDE_11.7.0_9198\ide\plugins\com.nxp.mcuxpresso.tools.wizards_11.7.0.202209140929\Wizards\
Product: MCUXpresso IDE
Version: MCUXpresso IDE v11.7.0 [Build 9198] [2023-01-17]
Operating system: Windows 10
VM: OpenJDK 64-Bit Server VM (64 bit)
Plugins and versions:
- com.crt.advproject (11.7.0.202212161200)
- com.crt.config (11.7.0.202301051331)
- com.crt.ctrlcenter (11.7.0.202207041044)
- com.crt.quickstart (11.7.0.202207200548)
- com.crt.utils (11.7.0.202301051348)
- com.crt.vendor.arm.generic (11.7.0.202207041044)
- com.crt.vendor.nxp.ctnxxx (11.7.0.202207041044)
- com.crt.vendor.nxp.generic (11.7.0.202207041044)
- com.crt.vendor.nxp.lpc11 (11.7.0.202207041044)
- com.crt.vendor.nxp.lpc13 (11.7.0.202207041044)
- com.crt.vendor.nxp.lpc17 (11.7.0.202207041044)
- com.crt.vendor.nxp.lpc18 (11.7.0.202207041044)
- com.crt.vendor.nxp.lpc43 (11.7.0.202207041044)
- com.crt.vendor.nxp.nhs3xxx (11.7.0.202207041044)
- com.crt.vendor.nxp.niobe (11.7.0.202207041044)
- com.crt.vendor.nxp.pn7xxxxx (11.7.0.202207041044)
- com.nxp.gnudocs (11.7.0.202207041044)
- com.nxp.kex.standalone (1.0.0.202301120728)
- com.nxp.lpcxpresso.installation.docs (11.7.0.202207041044)
- com.nxp.lpcxpresso.instructiontrace.docs (11.7.0.202207041044)
- com.nxp.lpcxpresso.powermeasurement.docs (11.7.0.202207041044)
- com.nxp.lpcxpresso.swotrace.docs (11.7.0.202207041044)
- com.nxp.lpcxpresso.userguide.docs (11.7.0.202207041044)
- com.nxp.mcuxpresso.addons.docsupport (11.7.0.202301051331)
- com.nxp.mcuxpresso.addons.gnuscript.editor (11.7.0.202208110851)
- com.nxp.mcuxpresso.addons.gnuscript.editor.ide (11.7.0.202208291154)
- com.nxp.mcuxpresso.addons.gnuscript.editor.ui (11.7.0.202212151615)
- com.nxp.mcuxpresso.addons.imageinfo (11.7.0.202207041044)
- com.nxp.mcuxpresso.addons.peripheralsview (11.7.0.202212150950)
- com.nxp.mcuxpresso.addons.sdkbuilder (11.7.0.202212161139)
- com.nxp.mcuxpresso.azurertos.docs (11.7.0.202207041044)
- com.nxp.mcuxpresso.core.common (11.7.0.202209090853)
- com.nxp.mcuxpresso.core.datamodels (11.7.0.202301171311)
- com.nxp.mcuxpresso.core.datamodels.develop (11.7.0.202207041044)
- com.nxp.mcuxpresso.core.datamodels.interfaces (11.7.0.202207041044)
- com.nxp.mcuxpresso.core.datamodels.resources (11.7.0.202207041140)
- com.nxp.mcuxpresso.core.datamodels.ui (11.7.0.202301111404)
- com.nxp.mcuxpresso.core.debug (11.7.0.202301041353)
- com.nxp.mcuxpresso.core.debug.support.linkserver (11.7.0.202212161249)
- com.nxp.mcuxpresso.core.debug.support.pe (11.7.0.202207141132)
- com.nxp.mcuxpresso.core.debug.support.segger (11.7.0.202301041353)
- com.nxp.mcuxpresso.core.headless (11.7.0.202212050754)
- com.nxp.mcuxpresso.datamodels.generic (11.7.0.202212161200)
- com.nxp.mcuxpresso.datamodels.generic.ui (11.7.0.202211041732)
- com.nxp.mcuxpresso.freertos.docs (11.7.0.202207041044)
- com.nxp.mcuxpresso.ide (11.7.0.202301111342)
- com.nxp.mcuxpresso.ide.theme (11.7.0.202212171010)
- com.nxp.mcuxpresso.ide.welcome (11.7.0.202212061249)
- com.nxp.mcuxpresso.mqxrtos.docs (11.7.0.202212050846)
- com.nxp.mcuxpresso.powerprofile.docs (11.6.0.202207121119)
- com.nxp.mcuxpresso.romtable (11.7.0.202301051149)
- com.nxp.mcuxpresso.sdkcli.docs (11.7.0.202207041044)
- com.nxp.mcuxpresso.swo.core (11.7.0.202301091214)
- com.nxp.mcuxpresso.swo.ui (11.7.0.202212151543)
- com.nxp.mcuxpresso.tad.azurertos (11.7.0.202211021304)
- com.nxp.mcuxpresso.tad.common (11.7.0.202212092054)
- com.nxp.mcuxpresso.tad.freertos (11.7.0.202212161200)
- com.nxp.mcuxpresso.tad.zephyrrtos (11.7.0.202212092054)
- com.nxp.mcuxpresso.tools.bin.win32 (11.7.0.202301121712)
- com.nxp.mcuxpresso.tools.win32 (11.7.0.202209140929)
- com.nxp.mcuxpresso.tools.wizards (11.7.0.202209140929)
- com.nxp.mcuxpresso.trace.core (11.7.0.202212161200)
- com.nxp.mcuxpresso.trace.core.linkserver (11.7.0.202212161200)
- com.nxp.mcuxpresso.trace.ui (11.7.0.202210250737)
- com.nxp.mcuxpresso.zephyrrtos.docs (11.7.0.202207041044)
- com.nxp.swtools.clocks (11.0.0.202301120728)
- com.nxp.swtools.clocks.model (11.0.0.202301120728)
- com.nxp.swtools.clocks.swt (11.0.0.202301120728)
- com.nxp.swtools.common.ui.utils (1.4.0.202301120728)
- com.nxp.swtools.common.ui.utils.swt (1.2.0.202301120728)
- com.nxp.swtools.common.utils (1.1.1.202301120728)
- com.nxp.swtools.configuration (1.6.0.202301120728)
- com.nxp.swtools.core (13.0.0.202301120728)
- com.nxp.swtools.core.service (13.0.0.202301120728)
- com.nxp.swtools.dashboard (1.0.0.202301120728)
- com.nxp.swtools.databinding (1.4.0.202301120728)
- com.nxp.swtools.dcd.model (1.0.0.202301120728)
- com.nxp.swtools.dcdx (3.0.0.202301120728)
- com.nxp.swtools.dcdx.swt (1.0.0.202301120728)
- com.nxp.swtools.derivative (1.0.0.202301120728)
- com.nxp.swtools.derivative.rcp (1.0.0.202301120728)
- com.nxp.swtools.doc.mcux.ide (1.0.0.202301120728)
- com.nxp.swtools.docannotations (1.0.0.202301120728)
- com.nxp.swtools.eclipse (1.0.0.202301120728)
- com.nxp.swtools.expert (1.0.0.202301120728)
- com.nxp.swtools.framework (4.0.0.202301120728)
- com.nxp.swtools.icons (1.0.0.202301120728)
- com.nxp.swtools.icons.standard (1.0.0.202301120728)
- com.nxp.swtools.mcuxpressoide.adapter (1.0.0.202301120728)
- com.nxp.swtools.mcuxpressoide.addons (1.0.0.202301120728)
- com.nxp.swtools.mux (13.0.0.202301120728)
- com.nxp.swtools.mux.swt (12.0.0.202301120728)
- com.nxp.swtools.periphs (10.0.0.202301120728)
- com.nxp.swtools.periphs.controller (10.0.0.202301120728)
- com.nxp.swtools.periphs.gui (10.0.0.202301120728)
- com.nxp.swtools.periphs.gui.swt (10.0.0.202301120728)
- com.nxp.swtools.periphs.model (10.0.0.202301120728)
- com.nxp.swtools.plu (1.0.0.202301120728)
- com.nxp.swtools.plu.ext_tools (1.0.0.202301120728)
- com.nxp.swtools.rcp.analytics (1.0.0.202301120728)
- com.nxp.swtools.resourcetables (10.0.0.202301120728)
- com.nxp.swtools.sdkmanifest (1.0.0.202301120728)
- com.nxp.swtools.sdkproject (5.0.0.202301120728)
- com.nxp.swtools.sharedconfiguration (1.1.0.202301120728)
- com.nxp.swtools.snippets (1.0.0.202301120728)
- com.nxp.swtools.tee.controller (4.0.0.202301120728)
- com.nxp.swtools.tee.gui (4.0.0.202301120728)
- com.nxp.swtools.tee.model (4.0.0.202301120728)
- com.nxp.swtools.tutorial (1.0.0.202301120728)
- com.nxp.swtools.ui.inspector (12.0.0.202301120728)
- com.nxp.swtools.ui.inspector.graphical (13.0.0.202301120728)
- com.nxp.swtools.ui.targetcpu (12.0.0.202301120728)
- com.nxp.swtools.ui.views (12.0.0.202301120728)
- com.nxp.swtools.utils (1.0.0.202301120728)
- com.nxp.swtools.utils.swt (1.0.0.202301120728)
- com.nxp.swtools.validation (1.1.0.202301120728)
- com.nxp.mcuxpresso.sdk.sdk_2.x_mkl33z256xxx4 (2.8.0.201911251446)
lpcxpresso_supp
The screenshot you provided indicates that multiple Redlink server instances were running. I suggest the following:
  • Use "Clean Up Debug" from the IDE
  • Disconnect and reconnect the MCU-Link probe and target hardware
  • Close all the other MCUXpresso IDE instances
  • Restart MCUXpresso IDE
MCUXpresso IDE v11.7 is expected to work even with the older MCU-Link firmware (e.g. v2.263). However, MCUXpresso IDE v11.6 will not work with the newer MCU-Link firmware (v3.x). Details can be found in a parallel community thread.
MCUXpresso IDE Support
