Regarding AN13057 and the LCP55S28:
https://www.nxp.com/docs/en/application-note/AN13057.pdf.
When using the MCUXpresso IDE (11.5.1 or 11.6.0) clock tool, how do you set the cap banks for both the 16Mhz and 32 KHz crystals?
Since clock_config.c is generated from the tool, I assume that manually adding the calls to POWER_Xtal32khzCapabankTrim(..) and POWER_Xtal16mhzCapabankTrim(..) is not recommended.
Steve
Hello scornelius,
I have checked the clock config tool, yes, it doesn't include this , we only can add by manual.
Alice
Hello scornelius,
I can help to take request ticket to development team, while sorry I'm not sure whether will add it.
Alice
I appreciate that Alice.
Thank you for your help,
Steve
