JLINK_SYS_Report does no longer produces any output
rshipman
My Jlink script has a few calls to JLINK_SYS_Report but I don't seem to see the output in the MCUXpresso console window. This used to work last time I looked at it a few months ago. Has something changed to prevent this happening? Is there a setting?
The script is still being executed otherwise I wouldn't be able to debug by board.
It is probably something obvious, but I can't find it.
Many thanks.
MCUXpresso IDE v11.8.1 [Build 1197] [2023-10-27]
SEGGER J-Link GDB Server V7.94k
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, but this other thread looks so similar to your question, so, I will continue the support in the other thread.
Keep debugger startup output in a separate console tab? - NXP Community
Pavel
