Is it possible to install EASE in MCUXpresso?
1,101件の閲覧回数
np
EASE is a funky JavaScript-based scripting / automation plugin for Eclipse: and because EASE release 0.7.0 is compatible with Eclipse Neon, it should (in theory) also work with MCUXpresso. See: http://download.eclipse.org/ease/release/offline/
However, when I tried to install EASE 0.7.0, MCUXpresso only partially installed it: and even then, none of the integration features I expected to be there (Run As --> Ease etc) seemed to be present.
Has anyone successfully installed EASE in MCUXpresso? Thanks!
1,090件の閲覧回数
converse
Senior Contributor V
Suggest you try EASE 0.8 and MCUXpresso 11.4 - latest versions of both
if that fails, you are probably missing some dependencies. Report the reported problems.
