How can I get integrated function to install a plugin from the marketplace to work ?
I am using IDE 11.6.1 but tried 11.6.0 with same results
I go here:
Find the plugin I want and click "install"
I'm trying to install a plugin using the IDE from the market place and get this error:
I click OK and get this:
I click confirm and get this:
Solved! Go to Solution.
It works for me, so to me there is no issue on the plugin/server side.
Maybe you are in a restrictive VPN network? I have seen reports that this can cause issues, as not the full network traffic seems to be routed through.
Or that the security settings on your machine somehow cause this, as starting from Oct 14th 22 all traffic on the marketplace is with https.
But you can get the plugin directly from there to:
https://marketplace.eclipse.org/content/bined-binaryhexadecimal-editor
or from
https://bined.exbin.org/eclipse-plugin/
I hope this helps,
Erich
or from
I hope this helps,
Erich
Hi dkh
I just tested marketplace on my side but I didn't see probelm:
I click on install, I get this window
I use MCUXpresso v11.6.1. I would suggest you change anohter network.
Have a nice day,
Jun Zhang
Thank you. I will assume this is network or security issue. This can be closed
