How to select QSPI flash for RT1050 in MCUXpresso IDE v11.7.0 and J-Link v7.84a?
felix1
Hi NXP,
I use RT1050 with QSPI flash, and how to change the MCUXpresso setting to use QSPI flash?
I have read the following document in segger web site, but how to do in MCUXpresso IDE?
https://wiki.segger.com/i.MXRT1050#Enable_Flashloader
https://forum.segger.com/index.php/Thread/8480-SOLVED-How-to-select-QSPI-external-flash-for-RT1051/?...
Tags (2)
jingpan
Hi @felix1 ,
Please use RT-UFL.
1. copy;
2. When select device, just type in
Jing
felix1
No one use QSPI on RT1050?
How do you solve this issue in MCUXpresso v11.7.0 with J-Link?
jingpan
Hi @felix1 ,
Please use RT-UFL.
1. copy;
Jing
felix1
RT-UFL needs to modify JLinkDevices.xml
https://www.cnblogs.com/henjay724/p/14942574.html
"就是把 \RT-UFL-1.0\algo\SEGGER\JLink_Vxxx 路径下的全部文件拷贝覆盖到 \SEGGER\JLink_V686f\ 目录下即可"
I can not find JLinkDevices.xml in J-Link v7.84a, so I doubt it can work with new J-Link version.
Can NXP give another solution for this issue when MCUXpresso IDE update? Since NXP always suggest to use latest IDE and SDK.
jingpan
Hi, Yes, v7.84a hasn't JlinkDevices.xml. But that's no problem. Just copy it.
felix1
This github repository lacks 3 .flm files.
jingpan
Can you give me the link of the first picture?
Jing
jingpan
Thanks. I'll forward to Jay.
Jing
jingpan
Jay told me that there is some special requirement, he can't include those file.(I don't understand why...)
So please download from
https://github.com/nxp-mcuxpresso/i.mxrt-ufl/releases/download/v1.0/i.mxrt-ufl-1.0-with-flm.zip
Jing
