How to read LPC1769 terminal from MCUExpresso
miepmup
I am trying to read out the data that should be transmitted from the board (lpc1769) to my computer over usb with the DEBUGOUT() and DEBUGIN() command. I opened the periph_dac example from lpcopen, but whenever I run it, there is no option in MCUXpresso to read the serial data and it seems I don't find any COM ports in windows after running the example.
Any suggestions onto how I can read out these commands?
Carlos_Mendoza
You could try installing the latest lpc11u35 debug firmware to your board, this way you should be able to see the COM port on your computer, you can find some helpful inforation on this thread:
https://community.nxp.com/message/998470
Hope it helps!
Carlos Mendoza
Technical Support Engineer
