When I try to built it's okey but when trying to debug, an error appear: either "Binaries not found" or "Error with command: arm-none-eabi-gdb --version. Cannot run program "arm-none-eabi-gdb": Launching failed".
Some one knows about the procedure to correctly debug a code generated from matlab?
It will be very helpfull, thanks!
I appologize for the delay.
Can you post your project here so that we can have a review?
xiangjun rong
