How can I kill the welcome screen?
2,600 次查看
laszlomonda
How can I kill the welcome screen of the MCUXpresso IDE? It always gets displayed when starting the IDE and I never use it, so it's an annoyance.
Thanks!
- Laci
2,335 次查看
BlackNight
Hi Laci,
there is an option under Window > Preferences > MCUXpresso IDE > General > Show welcome view.
And if you want to customize the splash screen too, see Customizing Welcome View and Splash Screen in Eclipse Neon | MCU on Eclipse
I hope this helps,
Erich
2,335 次查看
laszlomonda
Thank you so much Erich and Con!
2,336 次查看
BlackNight
Hi Laci,
I hope this helps,
Erich
2,335 次查看
converse
Senior Contributor V
If it's the same as lpcxpress, there is a preference for it.
Window->Preferences->LPCXpresso->General 'Show welcome view'
