Headless builds fail with latest mcuxpresso release (11.9.0)
Maarten1
We use a docker image to run headless builds in Bitbucket pipelines.
Up until version 11.7.0_9198 this has been working fine, but with the latest version of the IDE (11.9.0_2144), it stopped working.
The command we are using is:
mcuxpressoide -nosplash -no-indexer --launcher.suppressErrors -application org.eclipse.cdt.managedbuilder.core.headlessbuild -build ProjectName/Release -data .
and the error content of the log file is:
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2024-01-26 13:58:38.465
!MESSAGE Recreating part support. No part support available.
!SESSION 2024-01-26 13:58:52.354 -----------------------------------------------
eclipse.buildId=unknown
java.version=17.0.7
java.vendor=Eclipse Adoptium
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -no-indexer -application org.eclipse.cdt.managedbuilder.core.headlessbuild -build ProjectName/Release -D BUILD_SERVER_VERSION=1.6.3+73 -D BUILD_SERVER_DATE=26-01-2024 -D BUILD_SERVER_TIME=13:58:28
Command-line arguments:  -os linux -ws gtk -arch x86_64 -no-indexer -application org.eclipse.cdt.managedbuilder.core.headlessbuild -build ProjectName/Release -data . -D BUILD_SERVER_VERSION=1.6.3+73 -D BUILD_SERVER_DATE=26-01-2024 -D BUILD_SERVER_TIME=13:58:28
!ENTRY com.nxp.mcuxpresso.core.datamodels 1 0 2024-01-26 13:58:57.043
!ENTRY org.eclipse.cdt.core 4 0 2024-01-26 13:58:57.473
!MESSAGE Error
!STACK 1
org.eclipse.core.runtime.CoreException: description is being loadded
at org.eclipse.cdt.internal.core.settings.model.ExceptionFactory.createCoreException(ExceptionFactory.java:25)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.setProjectDescription(CProjectDescriptionManager.java:860)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.setProjectDescription(CProjectDescriptionManager.java:817)
at org.eclipse.cdt.internal.core.settings.model.CExternalSettingsManager$1.run(CExternalSettingsManager.java:431)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager$5.run(CProjectDescriptionManager.java:508)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2382)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.runAtomic(CProjectDescriptionManager.java:504)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.runWspModification(CProjectDescriptionManager.java:472)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.runWspModification(CProjectDescriptionManager.java:444)
at org.eclipse.cdt.internal.core.settings.model.CExternalSettingsManager.settingsChanged(CExternalSettingsManager.java:441)
at org.eclipse.cdt.internal.core.settings.model.CExternalSettingContainerFactoryWithListener.notifySettingsChange(CExternalSettingContainerFactoryWithListener.java:48)
at org.eclipse.cdt.internal.core.settings.model.CfgExportSettingContainerFactory.handleEvent(CfgExportSettingContainerFactory.java:257)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.notifyListeners(CProjectDescriptionManager.java:2190)
at org.eclipse.cdt.internal.core.settings.model.AbstractCProjectDescriptionStorage.fireLoadedEvent(AbstractCProjectDescriptionStorage.java:272)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.getProjectDescription(XmlProjectDescriptionStorage.java:267)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescriptionInternal(CProjectDescriptionManager.java:427)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:409)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:403)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:396)
at org.eclipse.cdt.internal.core.settings.model.CfgExportSettingContainerFactory$CfgRefContainer.getExternalSettings(CfgExportSettingContainerFactory.java:101)
at org.eclipse.cdt.internal.core.settings.model.CExternalSettingsManager$ContainerDescriptor.getExternalSettings(CExternalSettingsManager.java:163)
at org.eclipse.cdt.internal.core.settings.model.CExternalSettingsManager.checkExternalSettingsChange(CExternalSettingsManager.java:684)
at org.eclipse.cdt.internal.core.settings.model.CExternalSettingsManager.processContainerChange(CExternalSettingsManager.java:501)
at org.eclipse.cdt.internal.core.settings.model.CExternalSettingsManager$2.run(CExternalSettingsManager.java:615)
at org.eclipse.cdt.internal.core.settings.model.CExternalSettingsManager.handleEvent(CExternalSettingsManager.java:631)
at com.crt.config.database.TargetConfig.readProjectStorageElement(TargetConfig.java:396)
at com.crt.config.database.TargetConfig.getProjectStorageData(TargetConfig.java:320)
at com.crt.config.database.TargetConfig.getProjectStorage(TargetConfig.java:298)
at com.crt.config.database.TargetConfig.loadTargetConfig(TargetConfig.java:353)
at com.crt.config.database.TargetConfigDatabase.load(TargetConfigDatabase.java:92)
at com.crt.config.database.TargetConfigDatabase.load(TargetConfigDatabase.java:76)
at com.crt.config.database.TargetConfigDatabase.getDefault(TargetConfigDatabase.java:55)
at com.crt.config.database.TargetConfig.findTargetConfig(TargetConfig.java:110)
+ cat /opt/atlassian/pipelines/agent/build/.metadata/.log || true
!SESSION 2024-01-26 13:58:28.524 -----------------------------------------------
java.version=17.0.7
Framework arguments:  -no-indexer -application org.eclipse.cdt.managedbuilder.core.headlessbuild -importAll . -cleanBuild lpc15xxLib/Release
Command-line arguments:  -os linux -ws gtk -arch x86_64 -no-indexer -application org.eclipse.cdt.managedbuilder.core.headlessbuild -importAll . -cleanBuild lpc15xxLib/Release -data .
java.version=17.0.7
!MESSAGE Error
!STACK 1
at com.crt.config.database.partssupport.AbstractLinkerScriptHandler.findEntry(AbstractLinkerScriptHandler.java:83)
at com.crt.advproject.custom.optionhandlers.CRPOptionsApplies.getLinkerScriptExtension(CRPOptionsApplies.java:41)
at com.crt.advproject.custom.optionhandlers.CRPOptionsApplies.isOptionValid(CRPOptionsApplies.java:67)
at com.crt.advproject.custom.optionhandlers.CRPOptionsApplies.isOptionVisible(CRPOptionsApplies.java:110)
at com.crt.advproject.custom.optionhandlers.CRPOptionsHandler.setCRPeDefines(CRPOptionsHandler.java:153)
at com.crt.advproject.custom.optionhandlers.CRPOptionsHandler.apply(CRPOptionsHandler.java:52)
at com.crt.advproject.custom.optionhandlers.CRPOptionsHandler.open(CRPOptionsHandler.java:128)
at com.crt.advproject.custom.optionhandlers.CRPOptionsHandler.handleValue(CRPOptionsHandler.java:99)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.performValueHandlerEvent(ManagedBuildManager.java:3093)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.performValueHandlerEvent(ManagedBuildManager.java:3049)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.ConfigurationDataProvider.load(ConfigurationDataProvider.java:406)
at org.eclipse.cdt.managedbuilder.internal.dataprovider.ConfigurationDataProvider.loadConfiguration(ConfigurationDataProvider.java:573)
at org.eclipse.cdt.internal.core.settings.model.CConfigurationDescriptionCache.loadData(CConfigurationDescriptionCache.java:139)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescription.loadDatas(CProjectDescription.java:199)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.loadProjectDescription(XmlProjectDescriptionStorage.java:510)
at org.eclipse.cdt.internal.core.settings.model.xml.XmlProjectDescriptionStorage.getProjectDescription(XmlProjectDescriptionStorage.java:240)
at org.eclipse.cdt.internal.core.settings.model.CProjectDescriptionManager.getProjectDescription(CProjectDescriptionManager.java:636)
at org.eclipse.cdt.core.CCorePlugin.getProjectDescription(CCorePlugin.java:1402)
at org.eclipse.cdt.managedbuilder.internal.core.HeadlessBuilderExternalSettingsProvider.hookExternalSettingsProvider(HeadlessBuilderExternalSettingsProvider.java:63)
at org.eclipse.cdt.managedbuilder.internal.core.HeadlessBuilder.start(HeadlessBuilder.java:661)
at org.eclipse.cdt.managedbuilder.internal.headlessbuilderapp.HeadlessBuilderWrapper.start(HeadlessBuilderWrapper.java:131)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:203)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:136)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:402)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:255)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:659)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:596)
at org.eclipse.equinox.launcher.Main.run(Main.java:1467)
at org.eclipse.equinox.launcher.Main.main(Main.java:1440)
!SUBENTRY 1 org.eclipse.cdt.core 4 0 2024-01-26 13:58:57.474
!MESSAGE description is being loadded
!ENTRY org.eclipse.cdt.core 4 0 2024-01-26 13:58:57.475
!STACK 1
!STACK 1
!SUBENTRY 1 org.eclipse.cdt.core 4 0 2024-01-26 13:58:57.476
!ENTRY org.eclipse.osgi 4 0 2024-01-26 13:59:01.423
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: No more handles [gtk_init_check() failed]
at org.eclipse.swt.SWT.error(SWT.java:4944)
at org.eclipse.swt.widgets.Display.createDisplay(Display.java:1199)
at org.eclipse.swt.widgets.Display.create(Display.java:1123)
at org.eclipse.swt.graphics.Device.<init>(Device.java:167)
at org.eclipse.swt.widgets.Display.<init>(Display.java:632)
at org.eclipse.swt.widgets.Display.<init>(Display.java:623)
at org.eclipse.swt.widgets.Display.getDefault(Display.java:2392)
at org.eclipse.jface.preference.PreferenceConverter.<clinit>(PreferenceConverter.java:100)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditorPreferenceConstants.initializeDefaultValues(AbstractDecoratedTextEditorPreferenceConstants.java:758)
at org.eclipse.ui.editors.text.TextEditorPreferenceConstants.initializeDefaultValues(TextEditorPreferenceConstants.java:291)
at org.eclipse.ui.internal.editors.text.EditorsPluginPreferenceInitializer.initializeDefaultPreferences(EditorsPluginPreferenceInitializer.java:44)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper$1.run(PreferenceServiceRegistryHelper.java:307)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(PreferenceServiceRegistryHelper.java:310)
at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefaults(PreferenceServiceRegistryHelper.java:134)
at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(PreferencesService.java:374)
at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPreferences.java:225)
at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:279)
at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:371)
at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences.java:624)
at org.eclipse.core.internal.preferences.EclipsePreferences.node(EclipsePreferences.java:759)
at org.eclipse.core.internal.preferences.AbstractScope.getNode(AbstractScope.java:41)
at org.eclipse.core.runtime.preferences.DefaultScope.getNode(DefaultScope.java:77)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultPreferences(ScopedPreferenceStore.java:222)
at org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferenceNodes(ScopedPreferenceStore.java:251)
at org.eclipse.ui.preferences.ScopedPreferenceStore.contains(ScopedPreferenceStore.java:308)
at org.eclipse.ui.texteditor.ChainedPreferenceStore.getVisibleStore(ChainedPreferenceStore.java:465)
at org.eclipse.ui.texteditor.ChainedPreferenceStore.contains(ChainedPreferenceStore.java:141)
at org.eclipse.xtext.builder.EclipseOutputConfigurationProvider.getBoolean(EclipseOutputConfigurationProvider.java:173)
at org.eclipse.xtext.builder.EclipseOutputConfigurationProvider.createAndOverlayOutputConfiguration(EclipseOutputConfigurationProvider.java:144)
at org.eclipse.xtext.builder.EclipseOutputConfigurationProvider.createAndOverlayOutputConfiguration(EclipseOutputConfigurationProvider.java:153)
at org.eclipse.xtext.builder.EclipseOutputConfigurationProvider.getOutputConfigurations(EclipseOutputConfigurationProvider.java:112)
at org.eclipse.xtext.builder.BuilderParticipant.getOutputConfigurations(BuilderParticipant.java:652)
at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:247)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant$DeferredBuilderParticipant.build(RegistryBuilderParticipant.java:164)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:70)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:525)
at org.eclipse.xtext.builder.impl.XtextBuilder.addInfosFromTaskAndBuild(XtextBuilder.java:455)
at org.eclipse.xtext.builder.impl.XtextBuilder.fullBuild(XtextBuilder.java:562)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:333)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:1020)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:247)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:419)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:618)
at org.eclipse.core.internal.resources.Project$1.run(Project.java:571)
at org.eclipse.core.internal.resources.Project.internalBuild(Project.java:609)
at org.eclipse.core.internal.resources.Project.build(Project.java:129)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager$2.buildProject(ManagedBuildManager.java:4492)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager$2.run(ManagedBuildManager.java:4469)
at org.eclipse.core.internal.resources.Workspace.run(Workspace.java:2402)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.buildConfigurations(ManagedBuildManager.java:4501)
at org.eclipse.cdt.managedbuilder.core.ManagedBuildManager.buildConfigurations(ManagedBuildManager.java:4381)
at org.eclipse.cdt.managedbuilder.internal.core.HeadlessBuilder.buildConfigurations(HeadlessBuilder.java:324)
at org.eclipse.cdt.managedbuilder.internal.core.HeadlessBuilder.start(HeadlessBuilder.java:724)
Maarten1
Hi Alice,
thanks for your response.
I have some followup questions regarding your remarks.
1) You say that I need to have an SDK installed. This particular project is using an LPC1518 so as far as I know, there is no SDK involved (nor part support). We also have other projects using processors which do have an SDK, perhaps that works but I haven't tried that yet.
2) I have checked if the GUI runs fine in this docker container, and it does. So no installation issues, there.
3) Same as 1), there is no SDK involved for this project
4) Yeah, I think we don't really need X11 forwarding for the automated buildserver.
As I already mentioned, this same method has been working for years. The only thing that has changed in the environment is the IDE version. If I switch back to the older IDE, everything works. But we really want to have the same version for our developers as for our buildserver. So sticking with the old version is not an option.
That being said, I think that the other discussion you mentioned might have some valuable insights. I will look into that.
Kind regards,
Maarten
Hello @Maarten1
Thanks for your sharing and suggestions.
I will feedback to development team, thanks.
Alice
Hello @Maarten1
Thanks for your valuable question.
Our MCUXpresso IDE team give some suggestions as below:
1) Quite recently, I’ve done some experiments based on another community report –
see  https://community.nxp.com/t5/MCUXpresso-IDE/Mcuxpressoide-JVM-terminated-Exit-code-1/td-p/1783768
Command line version of Eclipse works fine but, in that particular case, SDK needed to be installed.
2) Regarding the problem described below, first idea would be to make sure the IDE runs correctly with the GUI. So make sure the installer doesn’t throw any kind of error during installation and all dependencies are correctly installed in that Docker container.
3) The error “No part support available.“ from the log indicates that the SDK associated to the project being built is not found in the known location (see SDK Handling preferences page, SDK search roots in particular). Either copy it where the IDE expects it to be, either instruct the IDE to use a custom path – search for “change.sdk.roots” in the Release Notes and in the documentation.
4)I also see “No more handles [gtk_init_check() failed]” in the log. It’s either caused by the GTK installed on the host, either the IDE is being started without X11 forwarding over SSH.
Hope it helps.
Alice
