Error when import SDK zip into MCUXpresso IDE
Search instead for
Fan_xy
CUXpresso IDE v10.1.0 [Build 589] [2017-11-14]
FRDM-K64-AGM04 SDKv2.3
When import the SDK zip package into MCUXpresso IDE, it shows erro :
What am I missing ?
Thank you very much!
Fan
Fan_xy
Hello ,
After I change the location of .zip, the error still exist.
And I have download  and install the latest version MCUXpressoIDE_10.1.1_606.exe, the same error.
BTW, my system is win10 pro.
Thanks.
Fan.
michaelzhangca
You can try download the zip file to another location(eg: c:\temp\) and drag the zip file to the 'Installed SDK' area.
Fan_xy
Hello Micheal,
Thanks for your support , I will try it, and BTW, my PC is win 10 pro.
Fan
ZhangJennie
Hi Fan,
I just tested installing FRDM-K64-AGM04 SDKv2.3 to my MCUXpresso IDE 10.1.0, there is no error.
Please make sure if you select "MCUXpresso IDE" as toolchain before you download SDK. Please see this configuration as reference
Jennie Zhang
