Downgrade workspace to version 10?
Search instead for
alannilsson
How do I downgrade my workspace to version 10 from version 11?  I've had it with version 11, it is utterly broken.  I've spent more time fixing/working around/debugging the tool in the last week since I upgraded than I have done actual work on my code.  I'm fed up.
Can I downgrade the workspace or do I have to just take the hit and recreate all my projects?
ErichStyger
Senior Contributor V
Hi @alannilsson ,
- if you want to preserve your current workspace settings (colors, text editor settings, etc) and you have made changes to the preferences, you can export and import them again, see https://mcuoneclipse.com/2012/04/04/copy-my-workspace-settings/
- you do *not* have to recreate your projects! See https://mcuoneclipse.com/2013/02/02/eclipse-workspace-tips/ . I keep workspace and project directories separate, so I can easily move between Eclipse versions. I suggest the same for you.
- So you can go to your workspace location (in case you don't know where it is: https://mcuoneclipse.com/2012/08/01/show-workspace-location-in-the-title-bar/ ) and copy/use the projects from there.
- import your existing projects. There are several ways, including drag&drop, see https://mcuoneclipse.com/2020/07/12/eclipse-gems-tips-tricks-importing-projects/
I hope this helps,
Erich
