Does MCUXpresso IDE Support KEAZ128xxx4 Device?
Chao-2015
I try to install SDK for KEAZ128xxx4,but failed to find it in the processors List pane of Install MCUXpresso SDKs. I wonder whether it is supported by this IDE?
Thank you.
chao
Chao-2015
Hi Raul,
When will NXP support the KEAZ128xxx4 ?
Chao
RaRo
Hello @Chao-2015,
NXP supports the KEAZ128xxx4 device in the S32 Design Studio for Arm. The KEA is also included in Codewarrior and KSD, however these IDEs are no longer included in our support portfolio. And due that, we no longer recommend them.
So, we recommend you use the S32 Design Studio for KEAZ128xxx4.
Warm regards, Raul.
RaRo
Hello @Chao-2015,
As you mentioned, the MCUXpresso IDE does not support the KEAZ128xxx4.
Nonetheless, you could use our S32 Design Studio IDE for Arm® based MCUs | NXP Semiconductors which supports the device.
Also, you could download some sample software drivers for KEAZ64/128 using S32DS here.
Warm regards, Raul.
