Configuring mcuxpressoide.ini file for best performance
2,784件の閲覧回数
ptcaos
To get the best performance with MCUXpresso IDE, what are the correct configuration for "mcuxpressoide.ini" file? I have seen some parameters like "Xms" and "Xmx", but I don't know the best way to get a good performance.
Thanks.
9 返答(返信)
2,684件の閲覧回数
Pavel_Hernandez
Hello, I asked my partner, and they told me this... I don't recommend changing the parameters from the .ini file... What kind of use case needs to be improved?
Of course, customers can play with those parameters but there's no secret recipe that we're keeping it as a secret with regards to performance...
Pavel
2,674件の閲覧回数
ptcaos
Hello @Pavel_Hernandez
I have noticed that when I uninstall some componets, MCUXpresso IDE hangs. At the bar menu bottom, message "Refresh SDK repository" appears, but IDE seems hanged. Because of this I want to know if problem occurs because of a bad "ini" configuration file.
Thanks.
2,652件の閲覧回数
Pavel_Hernandez
Hello, did you have the last version of the IDE? some issues are fixed on MCUXpresso v11.9.1 but for that update, the recommendation is to use the red square if you want to stop it.
Pavel
2,641件の閲覧回数
ptcaos
Hello @Pavel_Hernandez,
I have installed version 11.9.0 Build 2144. I'm going to try 11.9.1.
Excuse me, but... mmm what is the meaning of your words "but for that update, the recommendation is to use the red square if you want to stop it"?
Thanks.
2,604件の閲覧回数
Pavel_Hernandez
Hello, this is the red button.
Pavel
2,694件の閲覧回数
ptcaos
Hello @Pavel_Hernandez ,
we use our FRDM-MCXA153 for teaching purposes in our university labs.
Thanks.
2,762件の閲覧回数
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get more information about your questions when I have more details I will contact you.
Pavel
2,718件の閲覧回数
ptcaos
ask me what information you need and I will send you.
Thanks.
2,698件の閲覧回数
Pavel_Hernandez
Hello, sorry for the late response I will ask my team, could you let us know what your target MCU is for the register.
Pavel
